jcatnite
Now for an update on my situation. I was able to repeat the problem. Heck it happens at every light. I pulled the carb but the intake was pretty much dry. It takes so long to pull the carb that the fuel might evaporate before I got it anyway. So I got to thinking. I remembered that I bought a colortune way back when I first bought the car in an attempt to tune the ZS. Well put the colortune in #3 and watched the combustion. Strong and light blue. You can see it grow from the spark to the rest of the window. It was cool. I never got anything but sooty orange with the ZS. Anyway, even when the idle was stumbling, the colortune stayed blue. I think that indicates that it isn't loading up?
So, I reset the float height to within 1mm of the recomendation. That put the fuel height in my bowl about 1.5mm higher. Cut the timing back to 16 degrees BTC. That is closer to what Jeff told me to run. I cleaned out the small amount of debris that collected in the float bowl and pulled all the jets and tubes one at a time and made sure they were clean. I found the secondary idle jet wasn't tight but I think the oring was sealed. (At first I thought I had a eureka moment)I tuned the carb richer and lowered the idle to fall to about 900 when it stumbles. That makes it run around 1200 the rest of the time. I reset the fuel pressure to 2.0psi. I think it is an intake vacuum issue that I am having. I have no provision to measure manifold vacuum but could never get more than 14" when the ZS was installed. May still be having the same issue.
Carb spray around the throttle shafts change nothing but there is varnish on the carb and intake in the throttle shaft area. It runs really well at around 24degrees BTC but we all now that isn't safe. That is why I dialed the cam in so many times. I still think I'm just not making good vacuum at idle and I'm not sure why. Combustion numbers are good and even. Leakdown test shows minimal leakdown. Guess I'll keep pluggin away at it. I'll get it or get over it and go ahead with the body teardown. I might switch back to a stock cam when I pull the motor for paint anyway. I know I'll be drilling and tapping that intake..
JC
JC
