TR5/TR250 Need guidance for replacing steering column bushings
Got_All_4
Bushings have been bad for years. Front silver ring is worn oblong. Just don't know where to begin to get these bushings out. Shaft is out of the car too and looks like the silver ring has to come off first? Thinking of drilling out the rubber tab on the side then pushing the bushings out.
Any help would be appreciated.
Got_All_4
Got_All_4
should be a big help. thanks.
now I've heard of guys putting in 2 bushings at the bottom. looks like there is just enough room.
ed_h
Yes, you may not even need to remove the old bushes.
Ed
Gliderman8
I recently replaced the bushings in my TR6. I went with the Delrin bushings and left the old ones in place.
The job turned out to be easier than expected and the feel of wheel is a lot better.
glemon
I had a 4A and then my TR250. After many years of ownership and driving I redid the steering wheel bushings on the TR250. Didn't know the steering on a TR could feel so good. I didn't know the steering on a TR could feel so good. I didn't take the old ones out, just jambed the new ones in. Pretty easy.
Got_All_4
Got_All_4
Too late for the non removal option. I got a lot going on here. Adding a overdrive tranny, modern radio, new choke cable and who knows what else once I get into it. Hopefully by the end of next week.
Gilderman8 I see you have the same color carpeting as mine. Is that Milton Wool? Got mine from TRF and after being installed for 15 years in an open top Roadster it filthy in spots. Do you know what I should use to clean it?
Gliderman8
Mine is also wool. I’ve never attempted to clean it so I can’t make any recommendations.
Got_All_4
Got_All_4
Yep getting there. Having trouble with everything! Can't get the rear tranny mount figured out. I'll start another post. Can't get the pics to come out of camera. What else...
Got_All_4
Got_All_4
OK I know it's been a while but between holidays, other car problems and delays in getting parts I finally have the new column bushings installed. Now trying to install the steering shaft is a bit concerning. Seems that the bushing holes are too small and no where did it say to ream out the holes to fit. I sprayed a Teflon dry lube on the shaft and was my first plan then some thin oil after the shaft wouldn't go in. Have a couple of extra bushings that I ordered so tried to slide them over the shaft and the same problem. Very hard to turn even in the proper location. So do these have to be reamed to size or what's going on?
B TR6 Need guidance on TR6 electrical issue Triumph 7
W Still need guidance Spridgets 0
jlaird I need a bit of advise and guidance Spridgets 11
CharlieCarpenter Need some guidance on transmission removal Austin Healey 5
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
K TR2/3/3A Does this fitting need a Whitworth wrench? Triumph 10
Gliderman8 TR6 Now I really know why I need new shocks Triumph 11
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
W Need advice on installing new side curtain glass Spridgets 1
AngliaGT General TR You Might Need Snow Tires for This - Drive Your Triumph Day 2023 Triumph 5
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
K TR6 Need help with Mimosa Yellow Paint Triumph 1
T Storing nuts and bolts (so you can find what you need) Austin Healey 7
AngliaGT Need Ideas on Selling Our Midget Spridgets 10
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
drooartz MGB OD question - need to warm up? MG 8
H Wanted Need Spare tire rod BJ8 Austin Healey Classifieds 1
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
shadowfever Wanted Need a Sprite Mk II bonnet Spridgets Classified 1
jackq Wanted Need a C Tach MG Classifieds 2
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
apbos New/Old wheels for my Speedwell Sprite. Need Center Caps Spridgets 13
tr6web TR6 Quit running after a few minutes - need advice Triumph 15
AngliaGT I Need to Resist - 1980 Ford Fiesta Other Cars 9
vette Need BugEye Generator Austin Healey 7
vette Need BugEye Generator Spridgets 4
Got_All_4 TR6 Distributor Gear Mounting Question Need End Float Washer Triumph 4
Madflyer For Sale Triumph GT 6 parting out need something Triumph Classifieds 10
KiwiStagguy Re building my power steering 71 Stag . Rust and pitting bad . Need a business name to fix it Triumph Classifieds 0
tinman58 TR2/3/3A Need super charger!! Triumph 7
B Wanted I need a small section of a bugeye bonnet Spridgets Classified 5
volunteer Wanted Need Door Seals, Vent Window Seals and Trunk Seal for Daimler ds420 Limo Jaguar Classifieds 23
John Turney Need a Better Demister? Austin Healey 5
K TR2/3/3A Need advice on what my TR3A might be worth..... Triumph 10
69MGC MGC Need one MGB/C Splined Hub MG 1
69MGC Wanted Need one MGB/C Splined Hub MG Classifieds 4
Gliderman8 General TR Need clarification on Triumph Competition Preparation Manual TR250 TR5 TR6 Triumph 4
S TR6 Need wisdom on tr6 brake calipers Triumph 6
J MGB Need help identifying these parts MG 6
S TR2/3/3A Need New Battery for TR3A Triumph 9
B MGB-GT Need help with MGB GT rattle MG 0
AngliaGT MGB Need a GT [or Three]? MG 1
T Need an Anti-Tramp Bar? Austin Healey 6
K TR2/3/3A Help! No start! Need input from you guys. Triumph 9
