Need exhaust header advice/source for Amos
BRSLimited
I usually adjust the carbs to highest idle and then richen them up about 1/4 turn just for that reason. For some reason these engines seem to like being a little richer anyway, at least here in Michigan.
T
Tinster
TR3driver said:
mtlman8 said:
it looks like those are 175 cd's. not cd 2's if they are than they are adjustable.
Just for clarity, I'll point out that there is only one main adjustment, which changes the mixture equally throughout the range. In fact it's somewhat dangerous on a modified engine, because you set the adjustment at idle, but it also affects the mixture at cruise. If your exhaust changes reduce backpressure at cruise, the mixture will probably go lean there even though it is adjusted to be correct at idle.
I believe this is a common cause of failure with tubular headers.
Randall- they are for sure 175 CD2. Jeff Palya rebuilt them and I have mixture needles I can adjust thru the top with the Roadster carb tool.
I wrote Ted an e-mail about purchasing all the other stuff I need to convert back to stock. You know me. I am anal about purchasing new hardware and tap/die everything.
thanks again,
dale
TR3driver
Great Pumpkin - R.I.P
Yeah ... I was surprised you asked the question :jester:
T
Tinster
Ha ha ha!!! Randall- particularly when you consider I replaced eveything with new gaskets and fasteners when I installed my Jeff Palya rebuilt intake manifold.
They guys at the specialty fastener shop love me.
Here's a photo of the final header repair, steel, cap being formed to shape.
Beer can are aluminum. Healthy Choice Clam Chowder is packaged in steel cans.
I prefer the steel to reduce the electrolysis action of the Al and Fe.
Almost bid time my Stock header.
Dale
T
Tinster
Hey Hey Hey!!
I won the OEM exhaust headers!
Thanks Randall.
Whay color shall I powder coat them?
dale
TR3driver
I like white, but cast iron grey is good, too.
Chartreuse??!! :jester:
Andrew Mace
Gee, Dale, it's almost as if you'd photographed the exhaust system on any of several of my cars! I've been doing that sort of patch for many, many years, having first learned about it in the classic Dick O'Kane book <span style="font-style: italic">How to Repair Your Foreign Car....</span> <span style="font-style: italic">Healthy Choice</span> cans are good, as are most <span style="font-style: italic">Campbell's Chunky</span> soup cans.
A couple years back, my sister was visiting me from her home about 110 miles away. As she got to where I was, the exhaust system on her Daewoo broke; it looked as if it had cracked before and someone had just put a clamp on bridging the crack. I took my usual Chunky soup can and another clamp and put it all together, knowing it would get her home and then to her mechanic...who pronounced it "good to go" after retightening one clamp! :banana:
T
Tinster
Yisrael! I would to visit you.
Well, I let everything harden and minimum 24 hours and put the carb compenents backs together. Engine fired right up on full choke. No leaks from the 2 header repairs. After warm-up: balanced the carbs to a noce, smooth 800-900 rpm.
I still get backfires from time to time at idle. I think this is due to air/fuel needle which I do nor quite understand. My plugs all look rich mixture
but my idle is within specs.
HELP!!!
thanks Dale
apbos Need exhaust help !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Spridgets 18
J MGB Need some Exhaust flange advice MGB< but really any of our old cars MG 0
J Need some expertise, broken exhaust maniford Triumph 9
Schroeders BJ7 Exhaust on a BJ8: do I need downpipes? Austin Healey 10
H Need advice, Should I Wrap the Exhaust Pipes? Austin Healey 7
M Need advise on new Exhaust Valves Triumph 12
David_K Help - I need exhaust mount photos Austin Healey 4
T Need help with exhaust part. Triumph 14
Wana Need suggestions regarding exhaust system Austin Healey 23
giwplay1 Everything you need to know before purchasing an Austin Healey Austin Healey 15
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
K TR2/3/3A Does this fitting need a Whitworth wrench? Triumph 10
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
Gliderman8 TR6 Now I really know why I need new shocks Triumph 11
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
W Need advice on installing new side curtain glass Spridgets 1
AngliaGT General TR You Might Need Snow Tires for This - Drive Your Triumph Day 2023 Triumph 5
M Wanted Need 59 Bugeye Dashboard. LHD. Spridgets Classified 1
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
K TR6 Need help with Mimosa Yellow Paint Triumph 1
T Storing nuts and bolts (so you can find what you need) Austin Healey 7
AngliaGT Need Ideas on Selling Our Midget Spridgets 10
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
drooartz MGB OD question - need to warm up? MG 8
H Wanted Need Spare tire rod BJ8 Austin Healey Classifieds 1
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
shadowfever Wanted Need a Sprite Mk II bonnet Spridgets Classified 1
jackq Wanted Need a C Tach MG Classifieds 2
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
apbos New/Old wheels for my Speedwell Sprite. Need Center Caps Spridgets 13
tr6web TR6 Quit running after a few minutes - need advice Triumph 15
AngliaGT I Need to Resist - 1980 Ford Fiesta Other Cars 9
vette Need BugEye Generator Austin Healey 7
vette Need BugEye Generator Spridgets 4
Got_All_4 TR6 Distributor Gear Mounting Question Need End Float Washer Triumph 4
J TR2/3/3A Need help with pivot and body bracket for hood Triumph 2
Madflyer For Sale Triumph GT 6 parting out need something Triumph Classifieds 10
KiwiStagguy Re building my power steering 71 Stag . Rust and pitting bad . Need a business name to fix it Triumph Classifieds 0
tinman58 TR2/3/3A Need super charger!! Triumph 7
B Wanted I need a small section of a bugeye bonnet Spridgets Classified 5
volunteer Wanted Need Door Seals, Vent Window Seals and Trunk Seal for Daimler ds420 Limo Jaguar Classifieds 23
Got_All_4 TR5/TR250 Need guidance for replacing steering column bushings Triumph 11
John Turney Need a Better Demister? Austin Healey 5
K TR2/3/3A Need advice on what my TR3A might be worth..... Triumph 10
69MGC MGC Need one MGB/C Splined Hub MG 1
69MGC Wanted Need one MGB/C Splined Hub MG Classifieds 4
Gliderman8 General TR Need clarification on Triumph Competition Preparation Manual TR250 TR5 TR6 Triumph 4
