TR6 need carb parts
Sumton
i have a triple carb ZS setup, and i decided it was finally time to get the triple choke cable. only problem is I am missing a couple of critical components.
see: https://www.mossmotors.com/Shop/ViewProducts.aspx?PlateIndexID=32750
part #41, and then the part just to the right and below is nla. plus i need the little hex headed screw that holds the cable itself in lower on the body of the carb.
anyone willing to sell me these parts? please don't tell me to contact Joe Cuerto of the like; i'll go that route if i need to.
www.ranteer.com/davescars/tr6
What you got against Joe ?
You don't owe him money do you ?
Goodparts also has that setup, so they may have what you need.
Perry
I don't know exactly what the difference is between the brackets or how interchangable they might be, but which bracket is needed may come down to which carb number the OP needs the bracket for. Up to and including 1972, the same bracket was used on the front and rear carbs. In 1973 only, a different bracket is called out for both the front and rear carbs. For 1974 and up, the '1973" bracket is used on the front carb while the rear carb used the "up thru 1972" bracket.
From looking at the OP's webpage, I have to assume that he has asked around within the Red River Triumph Club. Dave, have you tried talking with either Byron Carlson at Sportscar Warehouse in Arlington or Jeff Sloan at British Auto Specialists in Haltom City/Fort Worth(?)
If it's any help, the Zenith part numbers are ZEB17088 for the "up thru 1972" bracket and ZEB22931 for the "1973" bracket. Triumph part numbers are 517001 and RTC1276 respectively for those brackets.
