Need an Anti-Tramp Bar?
Tadek
Member
Hello,
It's been quite awhile since I posted here, but I have been enjoying trouble-free life with my BN2 so I had no need to bother anyone. :smile:
There is one thing that has been troubling me for some time, and that is rear movement during hard acceleration or deceleration (not braking, just lifting the foot off the accelerator pedal).
Please take a look at the video showing the diff:
https://photos.app.goo.gl/5CBv5G56BrXW2rrP8
and what happens with the springs:
Is this normal?
On top, when accelerating, decelerating or going into OD, the rear of the car seems to move sideways.
I do have an aluminum head and DW cam, so the engine has slightly more power than stock.
Do I need an anti-tramp bar kit, or are my springs just too old and weak?
There is no way I could move the diff like this with my hand when the car is stationary!
Tadek
BN2 '56
Bugeye '60 in restoration
Re: Need to a anti tramp bar kit??
Thanks Steve, saves me having to find that video.
Tadek, your axle movement is normal. Unless you're breaking things, you don't need them.
I have them because I broke the rear universal grease fitting, but I have significantly more power in my 6-cylinder. Steve is also correct, you need side exhaust.
I didn't learn anything from the video but I agree with Steve, I don't really think this indicates the need for a tramp bar. I think your description suggests it could be a spring eye bush gone bad.
When driving at a steady speed if you feel the car steer slightly when you transition back and forth between light acceleration and light deceleration (no brakes involved - just on & off the throttle) my bet is a spring eye rubber bushing has failed, most likely a front one because the front ones are the ones that locate the axle. When the rubber bushing fails (rubber grinds away) the spring and axle can move forward and rearwards and 1/8" of so - just enough to change the relative alignment of the front and rear making it "steer".
I had this happen to me a few years ago and it drove me nuts trying to figure out what was wrong. In my case it was subtle enough that I sometimes thought I was dreaming - its and old car and they wander :smile:.
It can be difficult to trace the problem because when you jack up the car, the axle comes to rest on the pads on the frame and the springs are still under some tension so wiggling by hand doesn't work. I had to finally release the u-bolts and free the springs from tension to feel the movement.
Dave
I really cant get much from the video either.
If you have side-to-side movement of the axle check the Panhard bar for wear, play, etc.
Many thanks gentlemen,
I would say my axle moves roughly same as on the video you posted Steve, just shot at a different angle.
the spring bushing could be a problem then - you may be right.
I do not mind that rear car twist when accelerating, however when quickly lifting the foot off the accelerator at speed on the highway it's less pleasant.
Tadek
Tadek,
Not to change the subject, but I'm curious and perhaps you can contact me via PM to address my questions:
Is there a Healey club or British car club in Poland? If so, do they have a website? What types of activities do they organize?
AngliaGT '97 Miata - Need to Replace the EGR valve - recommendations? Other Cars 7
Got_All_4 Wedge TR7 Speedo Problems Need a Repair Place Triumph 4
M For Sale 6.0 harmonic balance need rebuilding Jaguar Classifieds 0
tr6web TR6 Need advice removing downpipe nuts Triumph 4
giwplay1 Everything you need to know before purchasing an Austin Healey Austin Healey 15
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 5
K TR2/3/3A Does this fitting need a Whitworth wrench? Triumph 10
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
Gliderman8 TR6 Now I really know why I need new shocks Triumph 11
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
W Need advice on installing new side curtain glass Spridgets 1
AngliaGT General TR You Might Need Snow Tires for This - Drive Your Triumph Day 2023 Triumph 5
M Wanted Need 59 Bugeye Dashboard. LHD. Spridgets Classified 1
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
K TR6 Need help with Mimosa Yellow Paint Triumph 1
T Storing nuts and bolts (so you can find what you need) Austin Healey 7
AngliaGT Need Ideas on Selling Our Midget Spridgets 10
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
drooartz MGB OD question - need to warm up? MG 8
H Wanted Need Spare tire rod BJ8 Austin Healey Classifieds 1
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
shadowfever Wanted Need a Sprite Mk II bonnet Spridgets Classified 1
jackq Wanted Need a C Tach MG Classifieds 2
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
apbos New/Old wheels for my Speedwell Sprite. Need Center Caps Spridgets 13
tr6web TR6 Quit running after a few minutes - need advice Triumph 15
AngliaGT I Need to Resist - 1980 Ford Fiesta Other Cars 9
vette Need BugEye Generator Austin Healey 7
vette Need BugEye Generator Spridgets 4
Got_All_4 TR6 Distributor Gear Mounting Question Need End Float Washer Triumph 4
J TR2/3/3A Need help with pivot and body bracket for hood Triumph 2
Madflyer For Sale Triumph GT 6 parting out need something Triumph Classifieds 10
KiwiStagguy Re building my power steering 71 Stag . Rust and pitting bad . Need a business name to fix it Triumph Classifieds 0
tinman58 TR2/3/3A Need super charger!! Triumph 7
B Wanted I need a small section of a bugeye bonnet Spridgets Classified 5
volunteer Wanted Need Door Seals, Vent Window Seals and Trunk Seal for Daimler ds420 Limo Jaguar Classifieds 23
Got_All_4 TR5/TR250 Need guidance for replacing steering column bushings Triumph 11
John Turney Need a Better Demister? Austin Healey 5
K TR2/3/3A Need advice on what my TR3A might be worth..... Triumph 10
69MGC MGC Need one MGB/C Splined Hub MG 1
69MGC Wanted Need one MGB/C Splined Hub MG Classifieds 4
Gliderman8 General TR Need clarification on Triumph Competition Preparation Manual TR250 TR5 TR6 Triumph 4
S TR6 Need wisdom on tr6 brake calipers Triumph 6
J MGB Need help identifying these parts MG 6
S TR2/3/3A Need New Battery for TR3A Triumph 9
B MGB-GT Need help with MGB GT rattle MG 0
AngliaGT MGB Need a GT [or Three]? MG 1
