Nardi hub for a BN1?
55modified
I want to change from a moto lita to a Nardi wheel. Having trouble finding information on correct nardi hub part #. I have found adapter for the opposite swap but not for my plan so i will have to swap hub or boss out too. Any suggestions?
Moto Lita & Lempert wheels have a hole of 3-1/2" / 88mm (sounds like a German tank gun).
If the Nardi hole is smaller, maybe it could be enlarged; if larger, it would be pretty easy to make a ring adapter.
Nardi hubs are available for Spridgets - maybe Moss could tell you if the shaft splines are the same as the BN1.
Seems like it would be better to adapt the wheel to the readily available Moss hub.
Again, Lempert might be your best bet as he works with all different kinds of wheels.
His email is mlempert:atbellsouth.net
My trafficator is nonfunctional. Nardi rep says he doesn't think they make a hub for my car but i find that hard to believe.
I would modify a Motolita unit. They are much larger than the Nardi and a bit of time on the lathe should work.
