john_j
In answer to a number of peoples posts -
"Princess Limo" - used a bigger engine than 1098!
"Taxi" didn't use 1098
"A110 sedan" used big healey engine
"Didn't they make a little sports sedan too A55?" Can't think of it - there was an A40 sports, but that was early 50s and used the 1200 B series
"AH Sprite?" not with mechanical clutch and long propshaft
"Minors" all used 14" wheels (if you had one with 13 it was probably one that had been upgraded with spridget parts)
"Morris Cowley" wasn't A series, and didn't last long enough for the 1098 big crank anyway
"And the Austin valve cover may well mean it is from a van." In 65 the Austin vans available were Mini, Minor (yes, there was an austin as well as a Morris badged version) A50 (50s Cambridge shape, B series) and one or the other of JU, J2, J4, can't remember when these all stopped and started, but anyway they all used B series.
Minors had mechanical clutch (have a look here for parts https://morrisminorspares.co.uk/shop/index.php?cPath=781_872&osCsid=5b3b328ff7712f15bdb708a578496d3c) so I wonder if it is LHD minor gearbox with a Sprite engine, or a minor engine with sprite carbs?
Do you have the engine number - the one on the plate near plug #1, not the one cast in, that should tell us where the engine came from.
It could always be from some sort of special - home made long wheelbase Minor?!?
