Ok, this spring I am going to turn some attention to my lovely little Spitfire which I have been neglecting these past winter months. For one thing I am going to remove one of the two Weber carbs (two is just too much carb for that motor). I will probably sell the other carb on ebay (or here on the forum?) Anyway, one problem I have always had with this car ever since I installed the new pistons and the hotter cam and Weber carbs is oil coming from the rear seal area, especially when I turn the car off. I have replaced the rear seal twice to no avail.
Could this problem be due to too much crank case pressure? Has anyone run across a similar problem? If it is Crank Case pressure causing the oil to be forced out the back end, what can I do about it?
