Randy Forbes
They're not so common that I'd ever seen one in the 115-120 LBC engines that I've rebuilt (mostly MGBs, but with a high concentration of Big Healey 6s, maybe a dozen or so Spridgets, and a handful of TR-250/TR6 & GT6).My mechanic, Russ Thompson, says pistons in a shape like mine are common in LBCs, especially MGs.
I bought the car in 1999 so who knows if the pistons were like that then?
I did see one (1) MGB piston that had shown the slightest bit of top-land degradation, but not even so much as to affect the ring groove itself.
I think that falls into only a few basic reasons; sometimes the owner of the car just wants it done. This may be part & parcel of other major work, like a restoration (or merely wanting to clean up & paint the engine compartment).RAC68 said:Although I am not incline to rebuild my engine, having owned and driven my Healey for so long, I always wonder what triggers enough concern to rip into an engine rebuild...
Necessity, either from obvious (or embarrassing) smoking to knocking noises would rank high on the list. Preemptive maintenance, which like in Steve's case, could be predicated on low/irregular compression (or leak down) testing, spark plug readings, or the inability to keep the engine in time (a worn/stretched timing chain comes to mind).
My money says that the Number One (#1) most likely reason people will elect to get an otherwise decent running engine rebuilt, is low oil pressure.
Remember that in the earliest days of the Healey, it wasn't too long after decoking (decarburising) an engine was still commonplace; engines were only expected to see sub-100,000 mile intervals of service. We've come a long way.
Hi Guest!
