How's that for a lead-in! Before I get a bunch of comments on my 53 year old posterior, let me explain. I had the differential unit rebuilt a couple of months ago on my TR250 because my original one had what was called "excessive lash". The replacement unit, from a TR6, I was told, only needed new shims and a couple of bearing carriers to get it back to tolerance. It came back and was installed at the same time that I had a garage press in four new u-joints in the half shafts, installed Richard Good's adjustable trailing arm brackets, urethane bushings in the trailing arms and new s.s. nuts, bolts and lock washers. While everything was out I carefully checked to see if the differential mount was cracked in any way and I could neither see, or feel, anything amiss. Everything gets installed without problems. But I still have a knocking sound coming from the rear whenever I let out the clutch. Sometimes it's just solid knock; at others, it almost sounds like rocks being crushed.
I took it into Sears one afternoon after having a conversation with a couple of their mechanics, one can never be too careful these days. Anyways these guys did do their level best (and at no charge!) to find the knock. One guy sat in the car while it was on a lift and kept letting the clutch out while another poked around underneath trying to isolate the noise. Their conclusion was that the sound seemed to come from the differential, still. The differential unit itself was rock steady, so I'm confident it's not the dreaded broken pins. The other night I thought I heard what sounded like a u-joint going bad, it had that familiar squeak for a few seconds. Maybe the mechanic crushed a few roller bearings while replacing the u-joints. I know I'm missing a rubber packing piece from under one of the rear coils. That might cause some noise. I'm wondering if the adjustable mounting brackets could be a source of this knocking-I know one side of these brackets are designed to free float. Has anyone who has installed these noticed anything similar? Any other suggestions are greatly appreciated. I'm planning on spending another weekend under the car within the next few weeks and I'd like to have a game plan together.
