My new restoration tool
DavidApp
Just finished up my home brew rotisserie. Have not done a 180 flip yet but have got to 45 degrees no problem. Need to remove the doors before we go right over.
David
DavidApp
I would go broke doing it as a business as I am too slow. I did build the bench for my Smithy 3 in 1 machine.
It will be good practice for my welding on the Midget,
That is the result of a lot of mental design and redesign. Once I had the turnover area sorted the rest came together. I did look at videos of commercial ones to get ideas.
About $200.00 in material but I did draw on my stock of scrap steel from work. I was in the habit of collecting square tubing and angle cutoffs at work.
David
JPSmit
I suspect the rotisserie is more solid than the car just now (likely heavier too :ROFLMAO: )
Looks great! and now I want a Smithy 3 in 1 (except for me would it be a 4 in 1?) :rolleyes2: - off to search the interwebnet. :D
DavidApp
The Midget is fairly solid. Only the floor pan rusting out in the foot well area and a little under the seats. The rest so far looks solid.
The Smithy 3 in 1 is a good lathe but the mill part is turning out to be a little less so for me. Maybe more practice is needed or a lift block as I am having to have too much quill stick out which is not good. A DRO would help with the mill bit.
David
DavidApp
Thank you.
Kind of impressed Me when it flipped with no issues.
There are no drawings of it. It was just made upon the fly. The turnover part was my sticking point. Once that part was sorted out the rest just came together.
I have always preferred to work in 3D not on paper.
David
Bayless
David, can you show a photo of the rotation stuff? That would be interesting to see. The rest of it is really impressive.
DavidApp
I used 2 pieces of black iron pipe I had laying around. One was about 2" OD and the other would just not fit inside the 2" pipe. I turned the outside dimeter of the smaller pipe and bored the 2"pipe so one would slide into the other.
I made some thick washers with a 12mm hole that fit inside the small pipe to support the small pipe in my center bolt. Then a larger washer to retain the 2" pipe on the inner pipe. Bolted it to a piece of 1/2" x 3"plate I had in the pile of steel and used "U" bolts to hold the cross tube to the outer tube. I will weld it once I get the welder down to the shop.
I wanted to prove the concept before making it permanent.
The 1/2" x 3" plate is welded to a piece of square tube that slides over the 2" square tube main upright.
David
Bayless
Nice. Thanks for the photo.
Frank Canale
Great job David, I built my rotisserie I guess a couple of years ago. I bought a set of plans on line and then modified it the way I wanted. I have only used one end to support the back of the chassis while I am putting the tub together. I am down to a couple of weeks to finish up a project for a friends wife and then I will be back to working on my car. Really hot in my shop but anxious to get back to it. Cooler days will be here before we know it. Frank
A 100/6 BN4 Restoration Austin Healey 7
S Wanted Used Austin-Healy 100/100-6/3000 Restoration Guide By Gary Anderson And Roger Moment Austin Healey Classifieds 14
Cutrog1 For Sale Healey 3000 BJ8.... a restoration saga Austin Healey Classifieds 0
Greg Chait Wanted Stalled or Abandoned MG Restoration Projects MG Classifieds 3
H General MG MGYB--Semi-- restoration MG 2
D For Sale 1955 DAIMLER CONQUEST RUNS NEEDS RESTORATION. Other British Classifieds 1
JoeO 72 TVR Vixen hybrid restoration TVR 1
Rob Glasgow Restoration: What Would You Have Done Differently? Austin Healey 37
GeorgeC Rich Chrysler's "Introduction to Austin-Healey Restoration" Austin Healey 3
D Fascia Restoration Austin Healey 14
J Restoration Progress - Boot Installed Austin Healey 1
C For Sale Parts, Factory Manual, Restoration Guide for 1959 100-6 Austin Healey Classifieds 4
BigGreen For Sale Anderson / Moment Restoration Guide for sale Austin Healey Classifieds 0
SteveTheBrewer Spitfire Triumph Spitfire Restoration Blog Triumph 22
R Tr4 restoration books Restoration & Tools 2
F YouTube Healey Restoration Videos Austin Healey 5
R TR2/3/3A Re-start after total restoration Triumph 22
F GT6 Looking to sell - in progress restoration Triumph 19
R TR2/3/3A Restoration of 1954 TR-2 Long Door Triumph 6
Don Riicardo Reliant Scimitar GTE se5a restoration Other British Cars 23
R TR2/3/3A Starting TR-2 for first time after restoration Triumph 58
Josandra 1949 singer nine roadster restoration by ladies Other British Cars 20
C SoCal Restoration Shops Austin Healey 15
HealeyRick Coronet Cream Restoration Austin Healey 1
H Restoration Magazines and Books Spridgets 4
W For Sale 1961 TR3a - Full Off Frame Restoration Triumph Classifieds 0
T BT7 Hardtop Restoration Austin Healey 6
nichola TR6 1973 TR6 Restoration - it’s a roller again! Triumph 4
Got_All_4 TR6 Starting my frame restoration Triumph 32
F General MG Field find restoration question ... MG 5
R TR2/3/3A Restoration of 54 TR-2 Triumph 6
Lin Fairly new YouTube series on AH100 restoration Austin Healey 0
S TR2/3/3A Frame off vs. body on restoration Triumph 21
D For Sale Custom 1972 Triumph Spitfire [Restoration Project] Triumph Classifieds 0
V TR2/3/3A TR3A Chassis restoration Triumph 8
Z For Sale 1954 Austin Healey 100-4 BN1 Beautiful Restoration Austin Healey Classifieds 0
Z For Sale 1954 Austin Healey 100-4 Beautiful Restoration Austin Healey Classifieds 0
J TR2/3/3A Body Restoration - Inner Sill Replacement Triumph 38
Jim_Gruber Pages from Porter Spridget Restoration Manual on Seat Recovering, You Tube Videos Spridgets 4
A TR2/3/3A Restoration work near San Diego CA Triumph 2
JPSmit Restoration on a Budget Restoration & Tools 4
F Restoration Guide Austin Healey 2
D For Sale For Sale: 1972 Triumph Spitfire [Restoration Project] Triumph Classifieds 0
T General TR Ron's Vintage Auto Restoration - Salado TX Triumph 2
C Looking for SoCal restoration shop Austin Healey 4
Popeye Post-War Other Mayflower for sale...needs full restoration Triumph 0
Michael Oritt Anderson/Moment Restoration Guide for sale Austin Healey 8
R TR2/3/3A Restoration of 1954 TR-2 Long Door Triumph 22
J TR2/3/3A Starting my TR3 A restoration Triumph 8
J For Sale Healey Books: Anderson/Moment Restoration Guide; Robert Bentley; 100-6/3000 Factory Austin Healey Classifieds 7
