Hey gang. After a month of having my 78 midget over at the mechanics she is finally back and better then ever. $1300 later but it was all worth it. This car has a new battery, coil, Pertronix unit, rotor, distributor cap, NGK plugs, Pace Setter exhaust manifold, Weber DGV Carb with the Pierce manifold, fuel regulator with the proper gauge and a new original car jack on the way. The mechanic took care of the carb stuff and the other miscellaneous I did. I think Im good to go for this summer. I know I need to empty the brake fluid from the system due to using DOT 3 which I found out is a no-no. I'll get to that when I look at the front passenger calliper witch is sticking it seems. Im going to try and post some pics to share with all of you to see my little project. It needs some paint work from being in the Texas sun before I purchased it yet the body is solid with no rust areas eating at the body. I feel complete again. Now Im ready for spring!
Hi Guest!
