My Alfa - I figured out that thumping
I figured out that thumping noise from the rear end... Dropped the driveshaft on the way home from work tonight. /ubbthreads/images/graemlins/cryin.gif
So, should it bolt right back up, or is that where one of those rubber donuts goes?
Nunyas
ouch... /ubbthreads/images/graemlins/frown.gif
never had that happen to me before... everything still serviceable?
kennypinkerton
The bolt flange on the driveshaft looks fine even though I dragged it about 100 ft while pulling over. But I didn't have a flashlight to be able to see the pinion input of the axle - I hope it's ok.
tony barnhill
Great Pumpkin - R.I.P
****! Again, check everything under that rear end...remember, I put a new one it & I've never worked on an Alfa before!
I am going to yell at my buddy tomorrow - his mechanic was supposed to go over everything I did to check behind me!
kennypinkerton
No harm done. I just gotta get 4 hardened 9mm fine thread bolts and locknuts. I don't know if they weren't tight, or if they were just sheared somehow. Right now, the car is about 2 miles from my house, in a safe place. When I get the driveshaft bolted back up, I'll drive it home and double check everything down there. Not your fault tony.
tony barnhill
Well, it has gone about 250 miles since it was installed (including your trip home)
kennypinkerton
The thumping only started after I got home... Probably had lost a bolt or two by then. It only got louder/more intense just a second or 2 before I heard/felt the driveshft drop and flop once before I clutched it and pulled off the road. My first time in it top-down too - ahhh the memories. /ubbthreads/images/graemlins/grin.gif
Platinum
Only one "gibo" (donut) in the driveline, at the tranny output. Bolt 'er up and proceed.
OH!!! Do NOT replace the U-joints with anything other than ones supplied from an Alfa stockist. The ones most parts stores sell you will be a few thou's smaller O.D. on the cups and will destroy the shaft... Write that down now!
tony barnhill
No, Kenny, I didn't do anything with the u-joints!
kennypinkerton
Noted already. <Use Only Alfa Parts houses for u-joints> I think they should still be ok.. I didn't notice any looseness or binding in them when I played with it while waiting for my wife to come pick me up. I'll go try to get some bolts/nuts tomorrow and get the car home.
Platinum
TONY!!! I was just passin' a concern thru with regard to replacement ~whenever~!! There'd be no reason you'd not SEE the mismatch if you DID do U-J work on "Pinky."
BWUHAAHAAAAA!!! "PINKY"... ~THAT~ has a double entante beyond belief!!!
...they just COME to me! /ubbthreads/images/graemlins/jester.gif /ubbthreads/images/graemlins/devilgrin.gif
Nunyas
... wow doc... you crack yerself up sometimes? /ubbthreads/images/graemlins/grin.gif
AngliaGT
Kinda like working on the night crew - you start laughing at things that others don't see as funny.
- Doug
kennypinkerton
I laughed at doc's comments too. But, back to business...
I found 2 sets of bolts that might get me home... or actually work for a while, until I get the right one's... But I need more of Doc's expertise!!!
I have a set of 8mm class8.8 bolts with matching nylock nuts..... and a set of Grade 8 5/16th inch bolts with matching grade 8 nuts and Loctite red thread locker... Which one should I use?... and for how long before getting the proper 9mm bolts n nutz from a junked alfa?
"they don't grow on trees" was an understatement... I spent 3 hours looking online for them and haven't found any yet.
Platinum
Use the 8mm class 8.8 bolts with matching nylock nuts... simply for the nyloc nuts, as they're sooo close to the same size... and DON'T forget to change 'em out for the proper shouldered ones. Soon. Driveshafts are even harder to come by now.
EDIT: Call Bob at Centerline. They have stuff they don't necessarily show on-line or in a catalogue.
kennypinkerton
Look what's home... 2 Pinky's hehehehehe.
Nunyas
lol is "The Brain" driving? /ubbthreads/images/graemlins/lol.gif
Platinum
That just went into my "Permanent Collection"!
BTW: I'm about to call Bob... gonna ~warn~ him about ya... and see if he's got an O/P sender for Luigi here. Stupid thing nearly stroked me out. Looked down and saw ZERO O/P at 4K!!! *GASP*
Been drivin' it like that for over a month now... needn't tempt fate anymore.
kennypinkerton
I noticed a little oil in my #1 plug well a few minutes ago. Could that be telling me I need a camcover gasket? I didn't see/feel any oil around the filler cap and it's gasket seems fine.
Pulled the dipstick /ubbthreads/images/graemlins/eek.gif I gotta go get some oil! Not even registering. Pressure guage shows good pressure though. oil light comes on at startup, but goes out in a few seconds as the pressure builds.
I gotta go get some oil anyway!
Platinum
SEVEN quarts at a time!
TRMark Alfa 4cyl engines Other Cars 8
P Alfa Spider Other Cars 1
P Alfa telephone repair Other Cars 2
DART Alfa Other Cars 2
glemon Alfa Romeo 4C Other Cars 10
steveg [OFF] Great Leno Garage vid driving Alfa 8C 2300 Monza Replica Austin Healey 1
glemon MGA and Alfa Scottsdale Spotted 0
DrEntropy Alfa gearbox issue Other Cars 2
T I need some help with an Alfa Romeo.... Other Cars 4
DrEntropy Alfa gearbox lunched Other Cars 16
DrEntropy 'nother Alfa Spotted 1
aeronca65t ALFA Spotted 5
Moseso 198something Alfa Spyder Veloce Spotted 1
C OT - Are Alfa's better? Triumph 19
DrEntropy Alfa throttle linkage? Other Cars 3
BugeyeNJ58 British and Italian Cars..Anyone owned an Alfa? Spridgets 20
Gray_Cat Alfa GTV 2000 Project Other Cars 4
bgbassplyr Alfa Giulietta..... Spotted 0
AngliaGT Alfa Berlina Spotted 8
T OT - Alfa arrived today Triumph 33
D Alfa Romeo Spyder Spotted 1
bgbassplyr Alfa Spotted 12
bgbassplyr Alfa Other Cars 1
DrEntropy Alfa wearin' [out] a speedo [cable]. Other Cars 5
T Learning about body work....Alfa Progress Other Cars 13
toysrrus `87 Alfa Romeo Milano Doors For Sale: Other Cars 2
toysrrus My sons 1st. Classic Car: `87 Alfa-Romeo Milano Other Cars 44
H Alfa Weber Carb Porn Other Cars 2
kennypinkerton Alfa Tinworm diagnosis... Other Cars 13
Flash MINI dealers to sell Alfa Romeos in the U.S. British Motor Corp 3
DrEntropy Just looked at an Alfa Other Cars 19
AngliaGT Hey Doc,is this an Alfa? Other Cars 13
B Paint systems explained: from Alfa BB Spridgets 4
kennypinkerton Selling the Toyota and maybe the Alfa Other Cars 2
H Alfa rally from Orlando to St. Augustine Other Cars 5
DrEntropy Alfa starter, round two! Other Cars 11
KLUTZ Parrish top for Alfa Romeo owners out there.kijiji Other Cars 1
H Traded 81 Alfa for 72 B and parts MG 7
H My new Alfa Other Cars 16
kennypinkerton For Doc... Alfa Pic. Other Cars 11
kennypinkerton The Alfa won... Other Cars 12
kennypinkerton Alfa Question... Other Cars 10
kennypinkerton Finally buying Alfa Spider parts... Other Cars 13
H alfa 5 Other Cars 9
H alfa 4 Other Cars 0
H alfa 3 Other Cars 0
H alfa 2 Other Cars 0
H alfa 1 Other Cars 0
H Alfa show in Celebration FL Other Cars 5
DrEntropy Alfa "Quality Time": Other Cars 8
