Berry, the accumulator bore on mine is not bad. I will try the buffing method used by CJD (John).
John, a couple of questions, did you install new steel accumulator rings, use the old ones, or did you go to the newer style accumulator? Also, when you buffed using polishing compound, how did you apply that, by hand or using something over the hone stones? Thanks!
Regards, Bob
Regards, Bob
