lbc_newbie
Anyone have experience with an MSD ignition or something comparable with a 1275? What is required for the install and tuning?
Morris said:IMHO, for about the same $$ and a little more work, you could install a Megajolt system and have dizzyless, multispark ignition.
Trevor Jessie said:Then I'd spend the money to ditch the Weber DGV and get some SU's and rebuild them. You'll see more of a gain in performance there.
Really, unless you are running really high CR at high RPM and a wild cam I can not see where you need anything more than a good basic ignition system.
aeronca65t said:So the electronic ignition is nice for easy of starting, warming up engine and driving it onto trailer. Never fouls a plug anymore and maybe has a small power gain at upper RPMs (I'd guess mostly because it keep the plugs cleaner with my rich-carb setup).
