richberman
I was wondering if anyone had a wiring diagram of how you wired your MSD ignition. I’m using points, so I can see they want me to disconnect the original wiring harness connections to the coil and replace them with the MSD orange and black leads. White wire from MSD replaces wire to dizzy. Red to ignition.
My questions are:
1)Where did you jump the Heavy Red and Heavy blacks to get battery power?
2) How did you wire in the battery cutoff switch?
3)What did you do with the original coil wires on the original harness?
thanks,
rich
You can see pictures of where I mounted here...
https://picasaweb.google.com/110087349657726745747/57AustinHealey#5720950779491188658
My questions are:
thanks,
rich
