Hi Guest! If you appreciate British Car Forum and our 25 years of supporting British car enthusiasts with technical and anicdotal information, collected from our thousands of great members, please support us with a low-cost subscription. You can become a supporting member for less than the dues of most car clubs. There are some perks with a member upgrade!
[ QUOTE ]
here is mr road test results
all in 4th gear
40 mph = 2000rpm
50 mph = 2500 rpm
60 = 3000
70 = 3000
75 = 3250
so what is my rear end
tires are 155/80/13
[/ QUOTE ]
Woodie,
Are those in miles or kilometers per hour? /ubbthreads/images/graemlins/lol.gif Either your tach or your speedometer is off. To be doing 75 mph at 3250 RPM you'd have a 2.85 rear. A 3.9 at 3250 if 55 mph. Get a GPS or follow a new car to verify speed to be sure.
Woodie, my '72 should be identical to your car, and at 3250, I'm spot on 55 mph. That's with 175-70's on it.
That was validated by a sheriff buddy following me in the cruiser for a speedo check, as I wanted to verify things after the tire swap.
Jeff
Woodie, can you get access to a GPS? They do pretty accurate speed calculations. I've used mine to verify my bike speed when I got a re-calibrated speedo face. Tunebug has no working speedo or tach, so I use a GPS when it matters.
When I first got the car on the road I was driving it at 60mph, my wife was behind in the cherokee, she said she was doing 60 as well. SO I don't get it, is 3750 rpms to low at 75 mph in 4th gear. I thought it was about right.
nope bought it in may of this yr. I did some minor body work, painted it, tuned it and droveit. I have had several minor issues, electrical, timing, and the sort, but nothing major. She drives real well. see pics at https://www.cardomain.com/ride/2354952
I'll see if I can do that in my head when I see a cruiser next time. Until I get a new speedo, I put some whiteout dots on the bezel, that formula is great.
Thanks John.
