mph / rpm ratio?
Baz
If I am doing 4000rpm in 4th gear (stock 4sp ribcase)
What mph am I doing?
Just trying to figure out if I deserved my ticket today or not?
1275, stock diff etc.
Finaly caught you did they. Also depends upon tire size.
I think I was doing 60, he said 65, 55 zone etc.
This was campus police.
Tire is 155/80 -13, I think I calculated 6% high with the tire size and took that into consideration, but my speedo is kaput, so I'm using the tach which is fine up to 40mph, after that I calibrate by throwing chicken bones on the passenger seat.
not enuff info but lets play suppose..........
tire diameter = 22"
diff gear ratio= 3.90
........................speed 67 mph
tire diameter = 23"
.......................... 70mph
gear ratio = 4.22
tire = 22"
...........................62 mph
radar gun? ... did you ask for calibration at that time?
estimated speed......mabe able to weasel out
clocked speed.....ask for speedo calibration report.
Short answer.....uphill fight unless you want to spend time seeing Judge Judy then still uphill./ubbthreads/images/graemlins/nopity.gif
For a 155/80R13 tire and a 3.7 rear you would be doing 67 mph.
"""""""""This was campus police."""""
Did the nice policelman used to work at the soup kitchen that Seinfeld used to frequent?
measure the roll out of your tire ...chalk the tread and revolve on the pavement eggzacly one revo and measure the length then math for diameter. Also post that and your diff ratio.
[ QUOTE ]
tire diameter = 22"
[/ QUOTE ]
That's about right, 22", it's fine, if I deserve it then I deserve it, It doesn't go on my record or have to tell insurance, so I'll get it worse from the Mrs when she gets home.
hang on a minute I got a 1275 4sp with 155/80 13 tires Im doing 65 at about 3200 rpm. So what the heck??? at 4000 rpm in 4th you musta been going faster than 65
Re: FIGHT THAT SUCKA!!!
""""""""It doesn't go on my record or have to tell insurance, """""
cummon.....who do you see then...Dean Wrightscool ?? If you go to Oldschool maybe it's a ruler across the knuckles? /ubbthreads/images/graemlins/hammer.gif
I would really ask for calibration......
Woodie /ubbthreads/images/graemlins/iagree.gif
My experiences have always been approximately twice the RPM's/100.
Patrick
That distance is 69" from chalk to chalk.
I have no reason to suspect I have anything other than a 3.909:1
Woodie, I personally don't think my car is capable of anything faster, from a mechanical pov, however, I'm curious too to see what this math comes out at, it could've been more?
Illinois has 'supervision' for 1st time offences, as long as I don't get another ticket in 30days, I'm home free. If I do, then both get tacgged on.
I've had my Sparky (1970 1275) up to about 75 mph, I m not sure what the rpms were , but they were still below 4000. I have 74000 miles on it. When I ran my spitfire (1980 1500 4 sp) it was almost exactly double rpms to speed, 3000 = just a hair over 60mph. I rememebr that cause the speedo did not work for awhile
Baz.....
rollout= 69.oo"
diameter= 21.97"
final drive = 3.90
rpm = 4000
SPEED..............= 67 mph. BUSTED !!
Barry, I use a Dream Wheel. It's a dedicated slide rule that has gear vs tire dia vs rpm vs speed and is accurate to about 2%. dont know if there even sold nowadays with palm computers and adders but it do save a lot of time on "what ifs".
Circumfrence to diameter use Pi. and convert to Dia.
Ok, I read that page,,, Im gonna check on the way home tonight, speed and rpms I'll report later or tomorrow morning
id be going more than 60 at 4000 rpm.....
mes thinks ur guilty /ubbthreads/images/graemlins/wink.gif
if i remember right, i pulled
off 75 for a minute the other day
was going about 4500rpm ....
dont care to go much faster /ubbthreads/images/graemlins/wink.gif
