JamesWilson
After working all summer and fall on welding the chassis and inner body together I've now reached the critical point where I'm about to mount the "A" and "B" pillars and the doors. I've several days off from the office, and hope to work on it more-or-less full time for the next week or so and hope to finish by mid-January.
The plan:
1.) Mount the front shroud (Scuttle, front X panel, inner wheel arches and inner/intermediate sills already mounted).
2.) Mount the rear brackets (that attach to the "A" pillars) to the front wings.
3.) Mount the front wings.
4.) Position the "A" pillars and tack in place.
5.) Mount the doors.
6.) Position the outer sills.
7.) Check the door gaps and alignment.
8.) Attach the "B" pillars to the rear wings.
9.) Position the rear wings.
10.) Check the door gaps and alignment
11.) Tack the "B" Pillars in place.
12.) remove front & rear wings and outer sills.
13.) Weld "A" Pillar in place.
14.) Tack Reinforcing panel for "A" pillar in position
15.) Weld "B" Pillar in place.
16.) Re-fit Front wings and doors.
17.) Re-fit rear wings.
18.) Check gaps and alignment.
19.) Tack outer sills in place.
20.) Remove wings & doors.
21.) Weld reinforcing panel in place.
22.) Weld outer sills in place.
23.) Re-fit front wings and doors.
24.) Re-fit rear wings.
25.) Check gaps and alignment.
Any comments or advice would be gratefully received. /ubbthreads/images/graemlins/yesnod.gif
TIA
James
The plan:
TIA
James
