MGTF1250Dave
Aloha All,
I started out researching various types of motor oil to see what might be best for my older LBCs, a '54 MG and a '58 TR3. The car maintenance manuals generally specify a 30 weight motor oil.
Modern engines have closer machined tolerences and most manufacturers specify 10W30 motor oil.
This is oil that is a 10 weight oil that will not thin more than a 30 weight oil when hot. This is acheived by adding polymers to a light base (10W), which prevents the oil from thinning as much when it warms up. At cold temperatures the polymers are coiled up to allow the oil to flow as the low number indicates. As the oil warms up, the polymers begin to unwind into long chains that prevent the oil from thinning as much as it normally would. Generally, the greater the viscosity span, the more polymer additives in the oil. These polymers break down over time resulting in engine deposits, viscosity and thermall breakdown.
The purpose of my long discussion was to say that multi viscosity oils are great for modern cars, but may not be best for older LBCs. My conclusion is that a single weight high detergent oil may be a better choice. I'm inclined to use an SAE 30HD motor oil. The temperature range in Hawaii is small, about 60 deg F minimum over night low in winter to 95 deg F maximum day time high in summer.
I would like your opinions on a motor oil for my cars. These are drivers, I use one to comute to work every day.
Safety Fast,
Dave
Safety Fast,
Dave
