This car is finally running since the engine was rebuilt in 1987. It sounds good, has good oil pressure, and maintains approx. 200 deg water temperature. After about 20 minutes of about 800 rpm running I shut it down and let it cool. Opening the radiator revealed motor oil floating on top of the water. I used a new head gasket, coated both sides with Hylomar, and torqued the nuts per the book (65 lb/ft). My son asked if I had sealed the head studs, as is necessary on small block Chevys. I had not, but I had not on other 100/4 engines either. Any help out there?
Hi Guest!
