motor oil [changes]
ron wilson
A couple of weeks ago there was a discussion regarding some ingrediants being recently removed from new oil that was going to adversely affect the engines in older vehicles.
I have tried to look up those posts without success. Can anyone direct me to this subject?
Here is something that I snagged off of another gearhead forum. I think it speaks directly to your question. It's been a hot topic on the Jag-Lovers Forum and was discussed here at length.
Randy '66 BJ8
OIL IS KILLING OUR CARS!!!!!
By: Keith Ansell, Foreign Parts Positively, Inc.
About a year ago I read about the reduction of zinc dithiophosphate (ZDDP) in the oils supplied with API approval that could affect sliding and high pressure (EP) friction in our cars. The reduction of these chemicals in supplied oil was based on the fact that zinc, manganese and/or phosphates reduce the effectiveness and eventually damage catalytic converters and introduce minute amounts of pollutants into our atmosphere.
A month or so ago I had a member of the Columbia Gorge MG Club bring a totally failed camshaft and lifters back to me that had only 900 miles on them!! I immediately contacted the camshaft re-grinder and asked how this could happen. They were well aware of this problem as they were starting to have many failures of this type. In the past, the lack of a molybdenum disulfide camshaft assembly lubricant, at assembly, was about the only thing that could create this type of problem. My customer has assembled many engines and had lubricated the camshaft properly and followed correct break in procedures.
This got me on the phone to Delta Camshaft, one of our major suppliers. Then the bad news came out: It’s today’s “modern” API (American Petroleum Industry) approved oils that are killing our engines.
Next call: To another major camshaft supplier, both stock and performance (Crane). They now have an additive for whatever oil you are using during break-in so that the camshaft and lifters won’t fail in an unreasonably short period of time. They also suggest using a diesel rated oil on flat tappet engines.
Next call: To a racing oil manufacturer that we use for the race cars (Redline). Their response: “We are well aware of the problem and we still use the correct amounts of those additives in our products”. They continued to tell me they are not producing API approved oils so they don’t have to test and comply. Their oils were NOT the “new, improved and approved” ones that destroy flat tappet engines! “We just build the best lubricants possible”. Sounds stupid, doesn’t it, New-Approved but inferior products, but it seems to be true for our cars.
To top this off: Our representative from a major supplier of performance and street engine parts (EPWI) stopped by to “warn us” of the problem of the NEW oils on flat tappet engines. This was a call that the representative was making only because of this problem to warn their engine builders! “The reduction of the zinc, manganese and phosphates are causing very early destruction of cams and followers”. They are recommending that, for now at least, there must be a proper oil additive put in the first oil used on new engines, beyond the liberal use of molydisulfide assembly lube. They have been told that the first oil is the time the additives are needed but remain skeptical that the first change is all that is necessary. Their statement: Use diesel rated oils such as Delo or Rotella that are usually available at auto stores and gas stations.
This problem is BIG! American Engine Rebuilder's Association (AERA) Bulletin #TB2333 directly addresses this problem. I had a short discussion with their engineer and he agreed with all that I had been finding.
Next phone call was to a retired engineer from Clevite, a major bearing and component manufacturer. First surprise was that he restored older British Motor bikes. The second surprise was that he was “VERY” aware of this problem because many of the old bikes had rectangular tappets that couldn’t rotate and are having a very large problem with the new oils. He has written an article for the British Bike community that verify all the “bad news” we have been finding.
Comp Cams put out “#225 Tech Bulletin: Flat Tappet Camshafts”. They have both an assembly lube and an oil additive. The telling sentence in the bulletin was “While this additive was originally developed specifically for break-in protection, subsequent testing has proven the durability benefits of its long term use. This special blend of additives promotes proper break-in and protects against premature cam and lifter failure by replacing some of the beneficial ingredients that the oil companies have been required to remove from the off the–shelf oil”.
Next question: Now what do we do?
From the camshaft re-grinders (DeltaCam) “Use oils rated for diesel use”, Delo (Standard Oil product) was named. About the same price as other quality petroleum based oils. They are not API formulated and have the zinc dithiophosphate we need in weights we are familiar with.
From the camshaft manufacturer (Crane): “use our additive” for at least the first 500 miles.
From General Motors (Chevrolet): add EOS, their oil fortifier, to your oil, it’s only about $12.00 for each oil change for an 8 ounce can (This problem seems to be something GM has known about for some time!).
From Redline Oil: Use our street formulated synthetics. They have what we need!
From our major oil distributor: Distributing Castro, Redline, Valvoline and Industrial oils: “After over a week of contacts we have verified that the major oil companies are aware of the problem”. “The representatives of the oil companies today are only aware of marketing programs and have no knowledge of formulation”. The only major oil companies they were aware of for doing anything to address this are Valvoline that is offering an “Off Road 20W-50” and Redline.
From Castrol: We are beginning to see a pattern emerging on older cars. It may be advantageous to use a non-approved lubricant, such as oils that are Diesel rated, 4 Cycle Motorcycle oils and other specified diesel oils.
Last question: So what are we at Foreign Parts Positively going to do? After much research we are switching to Redline Street rated oils and stocking the Castrol products that are diesel rated. Castrol, owned by British Petroleum, is now just a brand name. This is a difficult decision as we have been a dealer and great believer in all Castrol Products for over 40 years. We have been using Castrol Syntech oil in new engines for about 3 years so the cost difference in changing to Redline is minimal. The actual cost in operation is also less as the additive package in Redline makes a 1-year or up to 18,000 mile change recommended! Yes, it is a long change interval but with lowered sulfur levels and the elimination of lead and many other chemicals in the fuels there are less contaminants in our oil from the fuel, which is the major contributor to oil degradation. We will continue to offer the Castrol products but will now only stock the suggested diesel oils that they produce.
Too many things are starting to show up on this subject and it has cost us money and time. Be aware that “New and Improved”, or even products we have been using for many years, are destroying our cars as it isn’t the same stuff we were getting even a year ago.
For the cars that use “engine oil” in their gearboxes this may even pose a problem as these additives that have been removed could be very critical in gear wear. We will be using oil specifically formulated for Manual Gearboxes with Brass Synchronizers. The only oils we are aware of that fit the criteria are from General Motors and Redline.
If you have any additional input let us know. We need to let every flat tappet engine owner, i.e.: every British Car owner know that things are changing and we MUST meet the challenge.
Keith Ansell, President
www.ForeignPartsPositively.com
360-882-3596
In summary of Randy's post, Castrol GTX 20w/50 (which I've been using in my Healey for nearly 30 years) is still good for our cars.
Oil change intervals of 2500-3000 miles, or annually, if you don't put that many miles on your car.
I also use only Castrol 20-50 but if it is now only a front for BP are we really getting the same product? Who sell this additive and is it readily available form the Napas and Kragans? $12.00 per year is cheap insurance compired to replacement of lots of parts.
/ubbthreads/images/graemlins/savewave.gif
Yes TH, Castrol is a brand name owned by BP in the UK.But so is Arco which they also own.? So! who maintains the lowest gasoline prices here in the US?--Keoke- /ubbthreads/images/graemlins/smile.gif
As a side note, Castrol is the only oil recommended by BMW (for all its engines) and the only manufacturer of the TWS 10w/60 full synthetic oil required for the S-54 engined M3s (2001-2006) & M Rdstrs (2001-2002 & 2006-2007).
Castrol is also the only oil I've used since 1973 in any of my British sports cars (brief <u>free</u> trial period w/Quaker State). The best part was taking an engine apart that spent its life running Castrol oil__ZERO sludge buildup!
I just posted the entire 3 part article by Keith Ansell in the Spridget forum before I saw this post. Everyone may want to read this.
More on this from the Autox TR7/8 list.
A responswe from Castrol to an individual's online request for information.
Peter C
To: SNIP
Subject: RE: Castrol USA - Contact Us Form Data
Date: Mon, 18 Dec 2006 16:20:13 -0500
Thank you for contacting Castrol North America.
To clarify, in general, ZDDP levels have been reduced a small amount in the
current category engine oils (API SM/ILSAC GF-4) in compliance with industry
regulations that set maximum levels of Sulphur and Phosphorus, but are still
at levels that provide ample engine protection.
Castrol is aware of articles in enthusiast magazines and web-sites, as well
as after-market parts manufacturer discussions concerning GF-4 engine oils
and cam-shaft durability issues in older performance vehicles. Some
consumers suspect the lower level of ZDDP in GF-4 oils may be causing these
failures. Castrol is currently investigating this issue.
If you wish not to use a GF-4 oil in your vehicle, Castrol does offer the
following products that contain Zinc at a level that is higher than the Zinc
level found in oils (API SG) marketed during the "muscle car" era of time:
* Castrol GTX 20W-50 (SL,SM)
* Castrol GTX Diesel 15W-40 (CI4,CH4,CG4,CF4,CF,SL)
* Castrol GTX High Mileage 20W-50 (SL,SM)
* Castrol HD 30 (SL,SM)
* Castrol HD 40 (SL,SM)
* Castrol Syntec Blend Truck 15W-40 (CI4,CH4,CG4,CF4,CF,SL)(Semi-synthetic)
* Castrol Tection Extra 15W-40 (CI4Plus, CI4,CH4,CG4,CF4,SL)
* Castrol Hypuron S 15W-40 (CI4Plus,CH4,CG4,SL)(Semi-synthetic)
The following Castrol products have Zinc levels that are typical of API SG
oil:
* Castrol Syntec 5W-40 (SL,CF)(Synthetic)
* Castrol GO! 10W-40 Motorcycle Oil (SG)
* Castrol GO! 20W-50 Motorcycle Oil (SG)
* Castrol Grand Prix 4-Stroke Motorcycle Oil 10W-40 (SG)
* Castrol Grand Prix 4-Stroke Motorcycle Oil 20W-50 (SG)
* Castrol TWS Motorsport 10W-60 (SJ)(Synthetic)
Thank you again for your interest in Castrol, The Technology Leader!
Castrol Consumer Relations
Hi PeterC, The only oil I can find in the stores that specifically lists ZDDP in their oil, do not state in the API circle They are "Energy Conserving" Etc, is Valvoline VRI Racing oil. Further, Valvoline says their racing oil is not required to comply with the ILSAC requirements,---Fwiw--Keoke
