TR6 Motor mount changeover
pdplot
Planning to install TRF uprated front mounts in place of my cracked old mounts. Seems simple enough, but Murphy's Law still operative - at least around these parts. Any potential problems or is this something even I can do alone without f^%$#ing something up?
titanic
No experience with the uprated mounts but I would recommend moving the engine rearward as much has possible to make changing the fan belt easier. I only have about 3/8" clearance between the front on the damper pulley and the rack tube. It is a tight squeeze to r&r the fan belt.
Berry
P
pdplot
Mine is ok.I've changed the belt at least once - no problem. I'm just worried that the holes won't line up and the engine will be left hanging on the jack out in the driveway. My repair jobs always take twice as long and routine things go wrong.
W TR2/3/3A TR2 wiper motor mount Triumph 1
steveg Motor mount replacements Austin Healey 3
pa297pass TR4/4A TR4 wiper motor rubber mount installation. Triumph 7
CJD TR2/3/3A Motor Mount Shims Triumph 2
Jim_Stevens TR2/3/3A Wiper motor mount Triumph 4
TulsaFred Engine Install motor mount question Spridgets 5
GTP1960 TR2/3/3A Motor mount replacement Triumph 16
D Morris Minor motor mount? Other British Cars 3
D Weird motor mount?? Spridgets 7
steveg Motor mount alignment question Austin Healey 8
Rob Glasgow Motor Mount Cracks Austin Healey 10
Moseso TR2/3/3A PeterK, or others -- How did you mount your BMW fan on the TRactor motor? Triumph 3
B TR2/3/3A TR3 motor mount Triumph 9
T BN-1 Motor Mount Bolts Austin Healey 1
HealeyDave Motor Mount Question Austin Healey 6
T TR4/4A TR4a motor mount preferences? Triumph 5
ekamm TR2/3/3A tr3 motor mount Triumph 5
PatGalvin TR2/3/3A TR3 Shifter and Motor Mount Support Ques... Triumph 7
Trevor Jessie Motor mount pedestals Spridgets 8
bighly 1976 Midget Motor mount brackets needed Spridgets 0
T TR6 TR6 motor mount recommendations Triumph 4
A MGB motor mount spacer[s]? MGB MG 6
NutmegCT TR2/3/3A wiper motor mount grommets TR3A Triumph 7
kyreb1862 MGB Broken Motor Mount Bracket 77 MGB MG 2
kyreb1862 77 RB Motor Mount Replacement MG 0
A TR6 Motor mount position--front/back?? TR6 Triumph 2
J Motor mount reinforecment. Austin Healey 13
J TR2/3/3A TR3 fan and motor mount R&R Triumph 4
K TR2/3/3A New head gasket is installed.....did a compression check motor cold. Triumph 4
J For Sale Lucas 75150A Wiper Motor Other British Classifieds 0
D TR2/3/3A wiper motor parking? Triumph 17
B Windscreen Motor Repair Restoration & Tools 6
HealeyPassion Pop Quiz: Displacement of 2912cc motor bored 30 thousands (0.030) over Austin Healey 3
W General Tech 2500S starter motor and fuse box questions Triumph 3
K TR2/3/3A Further to changing motor and gearbox mounts. Triumph 1
R TR2/3/3A TR3 Wiper motor Triumph 10
SNClocks Upgraded Motor Mounts Spridgets 4
Joel Lester TR2/3/3A TR3 Wiper motor wiring and testing Triumph 5
Popeye Wanted WTB: two speed wiper motor TR4A / 75568 - Found Triumph Classifieds 2
M Engine Stand for 3000 Motor Austin Healey 7
E MGB MGB heater motor problem MG 3
edkap2002 TR6 starter motor advice Triumph 12
T Motor Jaguar 4.2 Jaguar 14
DocDup1 TR4/4A DR3A Wiper Motor Park Setting Triumph 4
B TR4/4A Too Many Wires? Wiper Motor Triumph 9
R 100 Motor and Gearbox Available Austin Healey 2
K TR2/3/3A Motor knocking at start up? Triumph 11
T TR2/3/3A wiper motor short Triumph 2
Darwin Spitfire Motor mounting help Triumph 1
3798j Off Topic My motor...it whistles... Triumph 2
