I bought one to use on the BMWs and modified an extra cap to use on the Healey. It works fine.
Instead of filling the bleeder with fluid, I only use it to pressurize the fluid in the reservoir. This requires a bit more attention on the part of the operator, but a LOT less potential for disaster if a leak develops at the cap/reservoir. Another benefit is less potential to introduce air bubbles in the liquid, acting on a smaller surface area.
I had an email exchange with Randy a while back and I could not get the "cap" to seal/ fit correctly on my reservoiur and after trying other caps none of them worked either. It was a costly purchase with no results and I finally went back to the two people old style brake bleeding. I may get a new cap for the Healey and add a fitting to it for my next attempt at it. Motive did not have a cap that worked!Steve,
I had not heard of the Cardone Master Cylinder Bleeder. Watched the video and really like the simplicity, and you can't beat the price. I just ordered one and will give it a try.
Randy, I will check the Motive cap for the Healey and check the fit before I do anything!
Thank you both. Love this Forum!
Lin
OK, I've been reading this and looking for a reason that they way I do it must be wrong, bad or ineffective. I'm sure you'll let me know if any of these are true. I went out and bought a pressure 1 qt. bug sprayer and simply put a tube on it that fit in the bleeder screw. I also made sure that the screws were sealed with some teflon tape so I could loosen them and not have air leaks. I know teflon tape is an anathema to some, but it does have its uses. I just push fluid (and all the air) up to the resevoir to bleed my brakes. All you have to be careful of is not overflowing the resevoir. Doesn't require a sealed cap for the resevoir and works well for me. Why push air down in opposition to wanting to rise when you can send it in the direction it "wants to go". I've had great success/luck with this and not had to buy anything but a $10 pump up bug sprayer. I even took the tape off when finished without introducing any air (bit of a mess, but easy). Been doing it with aircraft brakes for many years. A 50 cc syringe works great for pulling fluid out of the resevoir if it starts to get near the top.
No, mine's just a black plastic one; I don't think I paid that much for the whole rig! Mine's at least a decade old, maybe a dozen or more years, so the products have evolved a bitRandy,
is this the reservoir cap you use successfully on the Healey reservoir?
https://motiveproducts.3dcartstores.com/Black-Label-European-Adapter-1109_p_100.html
thanks,
Lin
ED, maybe I got the whole bleeding process wrong? Fill the bottle with "air" and then force the fluid out of the reservoir?Patrick, When I first tried to use my motive bleeder, the cap's threads were too thick which made it impossible to get the threads to engage the reservoir.
I put the little sanding drum in my dremel tool and removed a little material from the threads until the cap would screw down onto the reservoir. Worked like a
champ after that. The same cap fits the wife's Mercedes as modified. The motive tool is the greatest thing since sliced bread. I use it with different caps
to fit my other vehicles.
Like Randy, I never put any brake fluid into the tool. I just check/top off the level in the reservoir once in a while while bleeding the entire car. The tool is simply used
to apply a slight pressure to the reservoir. I just pump it up to 5 lbs with two or three strokes of the handle and that is enough to bleed until you are ready to check
fluid level again. I thought I had my clutch purged of all air until after I bleed it using the Motive tool. I have had a solid, non spongy feeling, clutch pedal ever since.
Ed
