TR6 Moss TR6 Vacuum Advance Conversion question
bunzil
It's probably been discussed here before but I couldn't find the thread so kindly bear with me...
I see Moss offers the conversion from retard to advance for later model TR-6's. Can someone give me their thoughts about how well this works versus just disconnecting the retard? Is it worth the $89?
Thanks, as always!
Bob Claffie
The "retard" distributor was strictly a smog tool and was detrimental to performance. I have no experience with the change over but if it was my car I would do it, Every other car benefits from an "advance" distributor why not yours ? Possiibly have to experiment with initial timing to blend in with the added advance.
TR3driver
Great Pumpkin - R.I.P
You should be able to see somewhere around 8-10% less fuel consumption on the highway with the advance. Looks like $4/gallon is here to stay, so do the math. $90 is 10% of $900, which is about 225 gallons (assuming $4/gallon). How long does it take you to burn that much fuel?
I'm surprised though, that Moss claims the advance port is there under a plug. The later carbs that I have seen do not have the advance port drilled (or tapped) at all. The location of the port opening into the carb throat is fairly critical for proper operation, so it's not a trivial thing to add. Might be worth checking before you spend your money.
But note that you aren't going to see any more power with the advance. Neither advance nor retard do anything at full throttle. You might be able to notice that the engine seems a bit more eager at part throttle (better throttle response), but even that effect is pretty subtle. Better gas mileage is really the only advantage of the vacuum advance.
poolboy
Since the retard worked off Vacuum, once the rpms exceeded 1100 rpms the manifold vacuum was inadequate to fully activate the retard, so I wouldn't classify is as being "detrimental to performance"...
NOx emissions were reduced by retarding the ignition timing when the engine was idling.
All the same, mine is disabled.
TR3driver
For all but TR250, the retard is actually connected to a special port that only 'sees' manifold vacuum with the throttle fully closed. So it gets deactivated as soon as you open the throttle, regardless of what manifold vacuum does.
On the TR250, there was a valve operated by the throttle linkage that did the same thing.
The retard does waste a bit of fuel and make the engine more prone to overheat (both only while idling). It also supports the feature found on later cars, where when the engine starts to get hot, the retard is disabled thereby raising the idle rpm and (hopefully) preventing a boil-over. It doesn't really affect performance otherwise. Mine (on the Stag) is only disconnected because the module is bad and replacements are not readily available. But if I ever get it running again, I do hope to do the advance conversion, for the reasons I stated above.
poolboy
You're talking about the throttle linkage vacuum valve..the 69 TR6 had that set up, too.
I guess technically it should be mentioned that high vacuum during engine overrun also activated the retard, but that would be a deceleration scenario and not affecting performance in a negative way, IMO.
B
bunzil
Thanks everyone. I've read about the retard countless times (there's a joke in there somewhere) but never fully understood it's role mostly at idle.
phil56
I converted my TR6 from vacuum retard to vacuum advance. The only issue I found is that the roll pin that holds the vacuum unit to the distributor body fell out, which resulted in the vacuum unit pushing itself out of the distributor body and severely retarding the ignition. This caused a significant loss in power. With the vacuum retard, if the roll pin falls out, the vacuum unit pulls itself into the distributor body when vacuum is applied. I have always seen vacuum units held to the distributor body with one or more screws. I installed a very small machine screw and nut in place of the roll pin.
S For Sale TR6 New Moss 73-76 Seat Foam Kit Triumph Classifieds 0
Got_All_4 TR6 Moss TR6 mechanical fuel pump TR6 Triumph 25
D TR6 TR6 Moss Header Triumph 7
G TR6 Moss TR6 Supercharger Triumph 31
71tr TR6 Moss replacement 2nd gear bush - TR6 Triumph 0
71tr TR6 Moss leather seat kits - TR6 Triumph 2
Bill Redd TR6 TR6 wiring - Moss Motors Triumph 10
A TR6 TR6- Group buy of Moss axle and hub conversion?,or Triumph 4
Scotsman TR4/4A Moss seat covers for TR4A missing spring tensioner pocket Triumph 0
Frameman 1949 New Moss Motors Fuel Tank Austin Healey 10
shadowfever Moss Motors MG Midget seat covers Spridgets 6
Celtic 77 MOSS response issues Restoration & Tools 11
BoyRacer Moss Motors Center Consoles Austin Healey 0
T TR2/3/3A Moss uprated water pump Triumph 6
C Alternative to Moss's BMC Green Engine Paint Austin Healey 10
M TR2/3/3A HVDA Replacement Clutch Disc Available from Moss Triumph 10
S TR2/3/3A Moss Motors Vitesse 5 Speed Conversion Kit Installation Issues Triumph 13
vette Latest Moss Motors Magazine Austin Healey 1
D MGB 3 Main bearing 1800 & Moss Supercharger MG 1
Basil MGB Moss Motors MGB - Jay Leno's Garage MG 3
K TR2/3/3A Moss Improved performance camshaft 851-051...... Triumph 0
BJ8Healeys For Sale Midget/Sprite nose section - used [Moss Motors P/N 455-145] Spridgets Classified 0
J For Sale Triumph TR2 TR3 TR3A New Moss Motors Black Karvel Style Carpet Kit Triumph Classifieds 0
3798j General TR Moss Motors acquires Victoria British Triumph 10
J TR6 Moss HS6 SU conversion kit question Triumph 4
steveg TR6 Moss advance kit maximum advance question Triumph 13
K TR2/3/3A Coil nuts? The SW and CB nuts on a Moss gold coil? Triumph 3
Upland Moss build-a-paper car contest Spridgets 1
K For Sale Front cockpit dash rail...N/A at Moss Triumph Classifieds 0
BLong63AH Moss Supplemental Heat Shield Austin Healey 2
Jim_Gruber In need of 2 Fulcrum Pin Bolts - MOSS Has them on Back Order Spridgets 3
Carlos TR4/4A Moss rear spring distance piece 674-560 Triumph 16
JPSmit Stirling Moss - Sebring Sprite Spridgets 3
KVH TR4/4A Door Seals: Moss Part 249-607 Triumph 0
Simmo TR6 Moss Seats Triumph 0
K TR2/3/3A Installing Moss wheel spacers? Triumph 5
E Moss stainless exhaust offering. Austin Healey 28
R TR2/3/3A New Control head wiring - Moss purchase Triumph 1
Michael Oritt Moss Motors rear brake "set" Austin Healey 11
K TR2/3/3A Moss Europe has restored the Jabbeke TR2 Triumph 0
Jim_Stevens For Sale Pair of chrome tail lamp bases, NIB, Moss 159300 Triumph Classifieds 0
LarryK Moss Motors buys XKs Unlimited parts house. Jaguar 6
P Moss Motors front brake calipers [BJ7 to early BJ8] Austin Healey 8
K TR2/3/3A The "compensator bar" on the Handbrake...#53 in Moss diagram Triumph 5
Jim_Gruber New MOSS Tapered Front Wheel Bearings - WTH are the instructions Spridgets 16
GTP1960 TR2/3/3A Moss Crankshaft pulley failure Triumph 23
L 100/ Moss Heat Shield Austin Healey 2
mt10flyer TR2/3/3A Moss Steering Rack Conversion Triumph 26
Jim_Stevens TR2/3/3A Goodridge SS brakelines from Moss Triumph 3
