TR6 Moss TR6 mechanical fuel pump TR6
Got_All_4
Last year I went back to a mechanical fuel pump in the TR250 after issues with a electric pump. A lot of talk at the time of the poor fuel pumps that were being produced. Then word came out that the mechanical pumps were much improved so I purchased one. Well Sunday the car developed a miss and discovered that the pump is making noises and the in-line filter you can see there is only a little spritz of fuel from time to time. Any one have any issues/problems with these new pumps?
Got_All_4
Got_All_4
Yes I do. However what made me go to the electric pump was the fact that the original rebuild failed and filled the crank case with 4 gallons + of fuel. The shaft seal is no longer available so when the diaphragm develops a hole there is nothing to stop the fuel from getting past the shaft and into the block.
The electric one worked very well but had no way to control the power to it. So when the car stalled it was always a challenge to get to turn off the ignition especially if your away from the car. I needed a fuel pressure cut off switch to really make it work.
I'm open for options?
DNK
They will rebuild the old ,BETTER than new
DNK
My link above
Quite a few TR6er's have had them rebuild their pumps
Brosky
You can easily rebuild your own. The kits do include the well seal to prevent fuel from going into the crank case.
TR6 Fuel Pump Rebuild
Just call and give them the numbers from your original pump to get the proper kit.
DNK
Paul, I use to think that too. Til, I saw what they where charging for them to do it.
Thought I saw $80.
Makes sense to have them do it. Unless it a rush job.
Might be a good winter project to have them build one and have it ready to go.
Brosky
Don, you are correct in that statement, as I saw $80 done complete as well. I just wanted to show that these are not that difficult to do, if he wanted to do his own. I like the idea of sending back an original and getting it back with a quick turnaround, if that's the path he wants to go.
Every part varies a little, so I would call and get a quote, just to be sure. they will ask for the numbers that are on the pump, along with year, make, model, engine, etc......
Brosky
Or you could call them and explain what you need and the time that you need it done in. They are very good about being honest and up front with time and cost estimates, from what I've been told.
BTW, I have no financial interest, just an interest in supporting the vendors with the best parts for the job.
simpson
My recent experience with MaritimeRacing - Then & Now Antique Auto
I sent them two nasty old orignal pumps by USPS priority flat rate and 5 days later got them back from them. I'm in SWFL and they are in Mass.
Forgot how to post pics, but they look great and one is on the car now, curing the problems created by the aftermarket Moss pump.
DNK
Thanks for posting that. Hopefully he'll go that route
Got_All_4
Got_All_4
I must have got my signals crossed. I just talked to Jeff at Advance Distributors and he is at Road America as were talking. I guess he only does distributors but mentioned he polished some fuel pump bodies for a few guys over the years. He told me that the Roadster Factory had the rebuild kits with the shaft seal too. So I'll try both places Thursday. Thanks!
Brosky
If you want the upgraded valves AND aircraft grade rubber, go with the first source. JMHO......
S For Sale TR6 New Moss 73-76 Seat Foam Kit Triumph Classifieds 0
B TR6 Moss TR6 Vacuum Advance Conversion question Triumph 8
D TR6 TR6 Moss Header Triumph 7
G TR6 Moss TR6 Supercharger Triumph 31
71tr TR6 Moss replacement 2nd gear bush - TR6 Triumph 0
71tr TR6 Moss leather seat kits - TR6 Triumph 2
Bill Redd TR6 TR6 wiring - Moss Motors Triumph 10
A TR6 TR6- Group buy of Moss axle and hub conversion?,or Triumph 4
Scotsman TR4/4A Moss seat covers for TR4A missing spring tensioner pocket Triumph 0
Frameman 1949 New Moss Motors Fuel Tank Austin Healey 10
shadowfever Moss Motors MG Midget seat covers Spridgets 6
Celtic 77 MOSS response issues Restoration & Tools 11
BoyRacer Moss Motors Center Consoles Austin Healey 0
T TR2/3/3A Moss uprated water pump Triumph 6
C Alternative to Moss's BMC Green Engine Paint Austin Healey 10
M TR2/3/3A HVDA Replacement Clutch Disc Available from Moss Triumph 10
S TR2/3/3A Moss Motors Vitesse 5 Speed Conversion Kit Installation Issues Triumph 13
vette Latest Moss Motors Magazine Austin Healey 1
D MGB 3 Main bearing 1800 & Moss Supercharger MG 1
Basil MGB Moss Motors MGB - Jay Leno's Garage MG 3
K TR2/3/3A Moss Improved performance camshaft 851-051...... Triumph 0
BJ8Healeys For Sale Midget/Sprite nose section - used [Moss Motors P/N 455-145] Spridgets Classified 0
J For Sale Triumph TR2 TR3 TR3A New Moss Motors Black Karvel Style Carpet Kit Triumph Classifieds 0
3798j General TR Moss Motors acquires Victoria British Triumph 10
J TR6 Moss HS6 SU conversion kit question Triumph 4
steveg TR6 Moss advance kit maximum advance question Triumph 13
K TR2/3/3A Coil nuts? The SW and CB nuts on a Moss gold coil? Triumph 3
Upland Moss build-a-paper car contest Spridgets 1
K For Sale Front cockpit dash rail...N/A at Moss Triumph Classifieds 0
BLong63AH Moss Supplemental Heat Shield Austin Healey 2
Jim_Gruber In need of 2 Fulcrum Pin Bolts - MOSS Has them on Back Order Spridgets 3
Carlos TR4/4A Moss rear spring distance piece 674-560 Triumph 16
JPSmit Stirling Moss - Sebring Sprite Spridgets 3
KVH TR4/4A Door Seals: Moss Part 249-607 Triumph 0
Simmo TR6 Moss Seats Triumph 0
K TR2/3/3A Installing Moss wheel spacers? Triumph 5
E Moss stainless exhaust offering. Austin Healey 28
R TR2/3/3A New Control head wiring - Moss purchase Triumph 1
Michael Oritt Moss Motors rear brake "set" Austin Healey 11
K TR2/3/3A Moss Europe has restored the Jabbeke TR2 Triumph 0
Jim_Stevens For Sale Pair of chrome tail lamp bases, NIB, Moss 159300 Triumph Classifieds 0
LarryK Moss Motors buys XKs Unlimited parts house. Jaguar 6
P Moss Motors front brake calipers [BJ7 to early BJ8] Austin Healey 8
K TR2/3/3A The "compensator bar" on the Handbrake...#53 in Moss diagram Triumph 5
Jim_Gruber New MOSS Tapered Front Wheel Bearings - WTH are the instructions Spridgets 16
GTP1960 TR2/3/3A Moss Crankshaft pulley failure Triumph 23
L 100/ Moss Heat Shield Austin Healey 2
mt10flyer TR2/3/3A Moss Steering Rack Conversion Triumph 26
Jim_Stevens TR2/3/3A Goodridge SS brakelines from Moss Triumph 3
