G
Hahaha, I wouldn't want to go there in one of these things much less stick around.
61TR3A said:I have a supercar for that already: 2011 R8 Spyder V10 with an old school gated 6-speed manual.
tinman58 said:I feel the same way! Drive for fun, the sound of the s/c has got to be cool as the looks of it in the engine compartment....
61TR3A said:I'm especially interested in acceleration in first and second and in the lower speeds as I rarely take the car anyplace where I get up to highway speeds, so 0-45 MPH is where I want to feel the added power.
martx-5 said:. That means you will be going from 100HP to 140HP. :
61TR3A said:They also say that all the parts are in-stock except for a special pulley required for the 83mm engine which requires a 6-week lead time. Once I know for certain what size pistons I have, I'm ready to place my order. Any & all suggestions how to determine my piston size short of removing the head are welcome.
61TR3A said:Actually, Moss advised me that the big boost kit isn't available for the 83mm cylinder blower. Could it be that the smaller bore engine already has higher compression and thus over-boosting might be too stressful on the engine? Maybe the best bet is to err on the side of caution by assuming my engine is original and to order that blower.
61TR3A said:As for the idea of installing a lightweight flywheel, my mechanic says it'll be very pricey - 25 hours - so that's off the table entirely. If ever I need to rebuild the transmission perhaps then I'll do it but for now I'll just go with the blower and an electric fan and eliminate the mechanical fan.
TR3driver said:For checking displacement, ideally you want something like a big burette. But they are kind of pricey, not worth buying for a single use
https://compare.ebay.com/like/370525397570
Probably you could get close enough though with just a rubber tube coupled to the spark plug hole, and a 500 ml (1 pint) measuring cup. Turn the cylinder to BDC and fill it with oil through the tube, working the piston up and down a bit to expel all the air. Then turn the end of the tube down and let the oil drain to the level of the bend in the tube. Hold the measuring cup under the tube and have someone else turn the cylinder to TDC while you hold the tube steady and catch the oil. If you get more than 500ml, then you have 86mm liners (or larger).
kellysguy said:...
3's put out almost as much as a US 6?
