I have purchased a Moss alloy valve cover and the polished brass crested nuts to install on my '73 'B My problem is that the nuts are too short. It would appear that the holes in the alloy cover are about 1/2" higher than the original cover.
I was thinking that maybe I should replace the front and rear studs with longer ones. If that is the solution, can I replace each one without undoing all the head bolts and rocker nuts as well or does that foul up the load on the rockers. Or, is there some other magic that I haven't thought of. Surely this must be a problem for everyone installing one of these alloy covers.
Thanks,
ceedub
Thanks,
ceedub
Hi Guest!
