DeltaAir423
Well after a small bit of half hearted looking, I took the plunge on a 1980 Spit 1500. Little rough, but should clean up nice. Currently on the list of parts to order for replacement are a new top (old one is shredded) and a new leaf spring.
This afternoon, I changed the engine trans and diff oil, and flushed the radiator. Now I've been reading up a lot on the thrust washer check, and it looks like I need to do that.
The big question I have is how many revs I should be pulling at 50-55 (currently 3000-3200), and possibly 70 mph (haven't ventured that far yet). It is a 4 speed without OD. Some ideas I'm kicking around are getting an OD transmission, and also possibly looking for a swiss spec ring and pinion. In my reading those were running at 3.27.
Any ideas?
By the way, the 70 mph figure is because I live in the Atlanta area, and if I were to drive it to work I would need to run at 70, and even then I'll probably get run over.
Any ideas?
