1.There is green wire that is attached to the back of the Ammeter with a ring terminal.There is another 6" green wire that runs off that ring terminal. What is that wire for....can't see anything on the wiring diagram for it? Also does the green ring terminal wire still go to the "B" side of the Ammeter if I have switched the system to NEG ground?
2.The hollow bullet like "caps" for the ends of the tail light wiring.(do they have a name?). Is the proper way to connect them to push the stranded wire out the small hole on the end of the cap,splay the strands out and push the cap on to the tail light wiring mounting holders or is solder required?
3.I'm adding a 4 fuse Lucas fuse box in addition to the existing 2 fuse box to wire in an electric fan and possibly the headlights. Where can I tie in the power source other than the ignition switch if that is too crowded. Run wires from the solenoid???
Any advice appreciated.:eagerness:
