WALTER
I went to check out my vacuum advance. A couple things seem to be wrong. (1)when I hooked up my vacuum pump to the distributor it would not rotate the plate. I could move it by hand while under vacuum then it would rotate back when vacuum was released. (2)I could not get vacuum from the manifold. I took the small plate off at manifold. I got vacuum from mounting screw hole but not from tiny whole where it's supposed to come from. Small wire went in about 1/2", sprayed w/carb cleaner no difference.
So, what might be clogging small hole and do I need to clean & lube my distributor?
Thanks
Walter
Thanks
Walter
