TR2/3/3A More on Fuel Pumps.....
karls59tr
Bronze
A friend of mine with a TR3 says when he starts his car it has to crank about half a minute before it fires. My TR3 fires immediately but I have an electric fuel pump. I think there was a thread on hard starting and hot weather recently. My friends starting issues are not necessarily confined to hot weather starting. Is it possible to have a "weak" mechanical pump or do they either pump or not pump? Could it be an issue unrelated to the fuel pump? He usually keeps his ignition and electrical up to snuff. Also , could enough fuel in a float bowl actually evaporate to cause hard starting?
I told him to get an electric pump but it seems some 3 drivers prefer to keep the mechanical one.
Any thoughts?
NutmegCT
Karl - just a thought. Does your friend have starting problems every single time he tries to start? or only if the car has been sitting a few days.
The original mechanical fuel pump has a primer lever; five or six hand pumps and it fills the carb bowls. And hopefully the fuel filter or lines aren't clogged.
Tom
Crankshaft
If my car sits for more than just a few days I fill the float chambers with the manual lever on the pump. Otherwise it does require consideraly more cranking time
charleyf
I prefer the mechanical pumps myself. One issue could be a lot of heat from the exhaust evaporating the fuel in the bowls. But I have not had such a problem. A heat shield would be the remedy to the heat problem.
charley
Geo Hahn
Does his garage smell a bit like gasoline?
I know some think since we have vented fuel systems there will always be some smell but I generally think a garage that smells like gas has a car with a (possibly small) fuel leak.
A slow leak from the carbs may not leave much visible evidence but will stink and will necessitate extra cranking (or priming) after sitting for a few days.
An engine w/o carb leaks should readily fire up even after sitting for a long spell.
Obviously an electric pump side-steps this -- though the symptom of a leak there is that you may hear the pump run for a second or two when you switch on the key.
TR3driver
Great Pumpkin - R.I.P
As others have alluded, my first thought is leaking float bowls. The rubber seals that the bowls mount on is a particular weakness in the SU H6 design. They rarely last me for as long as two years before they start leaking, and sometimes much sooner.
The engine should be able to start on the fuel stored in the float bowls. If the pump is not working, it won't run for long, but it should start and run for a few seconds. My TR3 fired right off yesterday after sitting in the driveway for two weeks, without even raising the hood.
Synchronizing the chokes is another operation that is sometimes overlooked. If one is too rich and the other too lean, it will be harder to start.
Also worthwhile trying a different set of plugs. With an engine that has been hard to start, the plugs can sometimes get 'glazed', which will make it hard to start even after the other issues have been resolved. Using too much choke can also cause this problem.
T More on mechanical fuel pumps Triumph 32
D TR2/3/3A More Fuel pump questions. Triumph 10
Gliderman8 More electric fuel pump questions... Triumph 6
aeronca65t more fuel pump problems MG 3
K more electric fuel pump ?s MG 8
Bayless More Prefect Progress Other British Cars 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
C MGB More Weber help needed MG 27
DrEntropy More lessons in Japanese engineering Other Cars 7
KVH General Tech More Technical Questions—TR4 Triumph 5
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
KVH General Tech More Engine Rebuild Questions Triumph 15
AngliaGT A Few More Spotted 6
AngliaGT Saw a Few More Spotted 0
Bob Claffie More Village pics Other British Cars 0
Bob Claffie More Village pics Other Cars 3
M TR6 More noob questions… Triumph 14
Bayless More Paint Other British Cars 3
AngliaGT A Few More Local Vehicles Spotted 5
Basil More BMW Z4 trials Other Cars 21
AngliaGT A Few More I saw Yesterday Spotted 10
SteveTheBrewer Spitfire More rust repair Triumph 1
AngliaGT A Few More along Highway 220 Spotted 3
Bob Claffie More pics from Falls Village Festival Other British Cars 3
Sherlock Another cruise night, more interesting British iron Spotted 2
Y MGB More things that seem odd.... MG 2
jlaird MGB More on Bee's status MG 6
AngliaGT A Couple More Spotted 0
tr6nitjulius TR6 TR6 meeting my Demands & Giving Back more! Triumph 2
tr6web TR6 More leg room needed Triumph 5
Got_All_4 For Sale Brake caliper pistons Ceramic Coated and more Triumph Classifieds 0
Nelson No more MG Midgets Spridgets 3
HealeyPassion Getting a bit more space for triple Webers... or EFI Austin Healey 3
K TR2/3/3A Auxillary Carb Return Spring in More BS about TR's. Triumph 0
K TR2/3/3A More pics of Kast Cam Triumph 4
K TR2/3/3A TR3A SU's More Pics Triumph 0
Ripper01 For Sale more TR-6 Used Parts Oct 2019 Triumph Classifieds 0
lbcspinners A- H Frog E: no more Bugeye oil leaks! Austin Healey 4
7 No more Bosch tools for me Restoration & Tools 4
D TR2/3/3A More small nuts [ and studs!] Triumph 2
C TR6 More fun with Lucas Triumph 5
Bayless More Sprite progress finally Spridgets 23
Bayless Even more progress - the Prefect Other British Cars 5
maxwedge5281 one more time.....mirrors! Austin Healey 14
Bob Claffie T-Series More or less TD action MG 0
R More Shroud to Scuttle install Austin Healey 4
Y MGB Answer to a question creates more new questions.... MG 12
K TR2/3/3A Auxillary carb return spring in "More BS about TR,s" Triumph 9
S TR2/3/3A little more door gap Triumph 14
Michael Oritt Replacing timing chain tensioner and more Austin Healey 24
