The real deal. From TRF.
Used 12 times (mine and other's) with no distortion.
PeterK said:Is the bottom plate aluminum or steel? I'm gonna have to change bottom plate to the TRF design. hmmmmm.
TR6BILL said:Note the offset on the aluminum plate, which keeps the threaded rod centered on the spring, and the cutout pattern of the plate, designed to fit perfectly.
If you want the pattern, I could trace it out on a piece of paper and send it to you, Peter.
