Hi Guest!
Just as it is would be fine by me.eschneider said:tony barnhill said:Got any photos of it with the bonnet attached?
next spring -- after paint, powder coat, chrome, and upholstery.....
swift6 said:You mean the simple and flexible steel chassis that the Ash body frame sits on right? :wink:
DrEntropy said:swift6 said:You mean the simple and flexible steel chassis that the Ash body frame sits on right? :wink:
Yeah-yeah, Shawn. You KNOW I meant the woodwork. :smirk:
:angel:Roger said:The Kent name was used to cover a whole range of pushrod OHV Ford engines that came along in 1959, and were made in 1000, 1200, 1300, 1340, 1500, 1600 sizes that I can remember, and maybe more!
The first versions were 3-bearing for the Anglia and Classic, then the 5-bearing engine came along and finally the crossflow.
Lotus engines were built on an overbored pre-crossflow 1500, and the water pump arrangement was part of the original design.
The engine was specifically designed for the Elan, and I don't believe any Elans had any other engine fitted. I also believe that there were very few 1500 Lotus TCs and they never got into production cars.
DrEntropy said:At just under 140 the Elan is a handful. With any more the rest of the driveline REQUIRES many cubic dollars' worth of upgrades. Would imagine that Moggie ash chassis would *splinter* without some re-enforcement with a 180 HP twink shoe-horn'd in it. :shocked:
