TR6 More fun with Lucas
ceedub
As we complete our resto on a '74 TR6, we again having fun with the electrics. This time we are unable to get the hazard lights working and therefore unable to get the signals working. When we pull the new hazard switch we get a dim lighting of the front LED signal lights and no lighting of the rear LED signal lights. We did find that we were getting 6.5 volts at the rear signal lights but obviously not enough to activate the hazard switch or illuminate the lamps. Our first thought was a lousy ground. The grounds in the vicinity of the lights appear OK but we were wondering if there might be some other ground not in the vicinity of the lamps that might need attention that we don't know about. Any ideas to move things along are appreciated. Thank you in advance.
TR3driver
Great Pumpkin - R.I.P
To check, run a temporary wire forward to a battery post, or ground you trust. Then check the voltage from the temporary wire to the hot wire at the lamp.
Sounds to me more like a bad (high resistance) connection in the hazard switch; so I might be trying a temporary jumper to supply 12v directly to either the turn flasher or turn switch.
glemon
agree with poolboy, if you use LEDs you may have comparability issues with your flasher. All can be made to work, but trying filament bulbs would give a better idea of whether the system is working with the load it was designed for.
dklawson
Agreed. Try incandescent bulbs to confirm the circuits work. You probably need LED rated flashers for both the hazard and turn signals.
C
ceedub
Good suggestions. Thanks for your input. It will be a few weeks before we can get together to try some alternatives but I will file a report on our successes.
Ceedub
NutmegCT More brake fun! Other Cars 3
Moseso More Weekend Project Fun! Triumph 8
lbc_newbie More fun with the Prince of Darkness Spridgets 9
G More dyno fun... Triumph 0
D Spitfire Need help making my Spit 1500 a little more fun... Triumph 24
John_Mc More Top Gear fun! Triumph 1
regularman More fun Spridgets 5
frankenstang57 more ebay fun Triumph 10
Bayless More Prefect Progress Other British Cars 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
C MGB More Weber help needed MG 27
DrEntropy More lessons in Japanese engineering Other Cars 7
KVH General Tech More Technical Questions—TR4 Triumph 5
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
KVH General Tech More Engine Rebuild Questions Triumph 15
AngliaGT A Few More Spotted 6
AngliaGT Saw a Few More Spotted 0
Bob Claffie More Village pics Other British Cars 0
Bob Claffie More Village pics Other Cars 3
M TR6 More noob questions… Triumph 14
Bayless More Paint Other British Cars 3
AngliaGT A Few More Local Vehicles Spotted 5
Basil More BMW Z4 trials Other Cars 21
AngliaGT A Few More I saw Yesterday Spotted 10
SteveTheBrewer Spitfire More rust repair Triumph 1
AngliaGT A Few More along Highway 220 Spotted 3
Bob Claffie More pics from Falls Village Festival Other British Cars 3
Sherlock Another cruise night, more interesting British iron Spotted 2
Y MGB More things that seem odd.... MG 2
D TR2/3/3A More Fuel pump questions. Triumph 10
jlaird MGB More on Bee's status MG 6
AngliaGT A Couple More Spotted 0
tr6nitjulius TR6 TR6 meeting my Demands & Giving Back more! Triumph 2
tr6web TR6 More leg room needed Triumph 5
Got_All_4 For Sale Brake caliper pistons Ceramic Coated and more Triumph Classifieds 0
Nelson No more MG Midgets Spridgets 3
HealeyPassion Getting a bit more space for triple Webers... or EFI Austin Healey 3
K TR2/3/3A Auxillary Carb Return Spring in More BS about TR's. Triumph 0
K TR2/3/3A More pics of Kast Cam Triumph 4
K TR2/3/3A TR3A SU's More Pics Triumph 0
Ripper01 For Sale more TR-6 Used Parts Oct 2019 Triumph Classifieds 0
lbcspinners A- H Frog E: no more Bugeye oil leaks! Austin Healey 4
7 No more Bosch tools for me Restoration & Tools 4
D TR2/3/3A More small nuts [ and studs!] Triumph 2
Bayless More Sprite progress finally Spridgets 23
Bayless Even more progress - the Prefect Other British Cars 5
maxwedge5281 one more time.....mirrors! Austin Healey 14
Bob Claffie T-Series More or less TD action MG 0
R More Shroud to Scuttle install Austin Healey 4
Y MGB Answer to a question creates more new questions.... MG 12
