<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by kmcormick9:
what circuits are ignition on? i would rather not mess with my actual ignition wiring, but other than that i cannot think of any thing that starts when i start the car<hr></blockquote>
Like I said – I’m not a Midget guy. But if they are remotely similar to the wiring in MGBs, then you should be able to make a connections in several locations without affecting anything.
I recommend that you first get a schematic for your model year car and look it over before you start the installation. A good schematic diagram should be available in just about any shop manual. Once you have that in hand – I’m sure that you’ll find that there are plenty of locations to safely make your connections. The master or main fuse block would seem to be your best bet.
As an example my 78 MGB has it’s fuse block located in the engine compartment on the passenger side firewall right next to the coil. A simple test to find a safe place to make your connection – would be to use a voltmeter find out what fuses/connectors are hot (+12V) and what are cold (0V) when you turn on & off your ignition key switch.
Likewise you might want to consider providing the fuel pump with it’s own dedicated fuse for extra protection.
Bret
