KVH
Hey guys! I was just thinking of the Good Old Days,
<span style="font-size: 20pt">LIKE WHEN I COULD DRIVE MY TRIUMPH </span>
As some of you helpful good folks know, my symptoms and clues in my saga to start my car, which ran great just last weekend, are:
a) nothing but a single click when turning the ignition key;
b) some smoke from the wires at the solenoid, but darn if I know which ones--it was unclear, and the smoke was slight;
c) the negative battery terminal was warm;
d) after cleaning the cables, confirming my battery is good with a load tester, and confidently trying the ignition again, the negative ground wire blew clean off the firewall--it appeared I had a loose or bad connection;
e) I installed a new ground and battery cable at the firewall, cleaned the cables yet again, and turned the ignition, and now I'm where I was Sunday afternoon--nothing but a click at the starter and a hint of something smokey.
Usually, I rule out a bad starter. This one was reconditioned 4 years ago. Maybe a brush? Time to pull the starter after all?
If this goes on much longer I'll be driving my old Buick this weekend.
Any final thoughts before I pull the starter (I guess I could jump the solenoid posts with a screwdrive)?
Hi Guest!
