I'm not going to do this until we get back from my nephew's wedding in September, but I have determined that I need to replace the timing change tensioners on my Hyundai Santa Fe 3.3L. I'm not sure which side is bad but will change them both anyway, along with the chains and guides. Symptoms are - a lot of chain slap noise when you first start the car, which goes away after a few seconds and oil pressure builds up. This tensioner is designed with a ratchet type mechanism that is supposed to keep the chains under tension when the engine is not running, then, when you start the engine and oil pressure builds up, the oil pressure causes the tension.
This is probably going to be the most daunting task I've undertaken, so I signed up for www.alldatadiy.com and they have very good step-by-step instructions for this procedure.
Cost to have dealer do this job: North of $1200 (and that's just to replace ONE tensioner. It goes higher if you start talking about both tensioners, chains, guides, etc. )
