Modifying Leaf Springs
Photo of the anti-tramps on my Rover V8 MGB with end of sway bar where its attached to body at left upper edge of photo....I'm gonna do something differently with this car..
Sway bar is attached to the axle by a single bracket oneach side atop the tube about 6" or so inboard of the backing plates. The ends point toward the front of the car and connect to similar brackets on the inside of the frame rails...
See, Joe, we need you to POST - not lurk! /ubbthreads/images/graemlins/devilgrin.gif
Well, hurry up!
Tony - This may not be applicable to your GRMS car and it's intended use BUT ----
Flailing my GTs around mountain roads, I have noticed that the rear tends to hold better if the tire pressure is lower in the rear than the front, especially if the car only has me onboard. I assume this to be due to the extra leaf in the rear spring which supposedly provides additional carrying capacity for the GT model. The point is - the rear springs are already too stiff for your purposes, especially since you have lightened the beast.
I think you are on the right track by removing leaves. I wouldn't worry about taking out another if I were you. Besides, you have lots of time to put it back in after you have road tested it, right?
