twigworker
Assuming that Tony, our resident Gentleman Farmer, has time to look into the "upward slop factor", I do love those technical terms, I will go ahead and try to describe my thought on the housing modification. Actually there are several. The heat and bend routine, visions of Reece Witherspoon in Legally Blond come to mind, might be the simplest but I could see where someone with great knowledge of torchology would be needed along with someone who could make up a comparative jig to insure accuracy. Obviously this would best be done on a full banjo unit as the bending would have to be done as closely as possible to the outboard plane of the carrier bearing. The inside cavity of the axle shell should be large enough to accommodate the repositioning of the shaft inside. This would end up being the least detectable route for scrutineering, not that one would deliberately bend the rules. Another method would be more involved in the engineering and machine work departments and certainly be obvious to even the local oil change guy, but it would also look like one of the high tech machinist detail oriented fanatics on this list had done it. It would involve removing all or a portion of the tube from the center section of a Salisbury axle and grafting it to a prepared banjo pumpkin. I have not looked too closely at a Salisbury axle with the intention of removing the tube whole from the center but it might be possible given enough heat and weld removing expertise. Cut the weld away, heat the joint and slide the tube out. The advantage of this would be to maintain as much of the tube length as possible and thereby make it possible to make the grafting joint as close to the banjo carrier bearing as possible. An alternative would be to slice the tube at it's junction with the Salisbury center section. If this were done the tube would have to have a length of like material grafted to it to bring the inner tube opening closer to the differential. In any event the joint would be made by fabricating a flange pair that would be welded each half to the tube and the cut banjo diff. The secret would be to have the working face of the banjo perfectly vertical and the working face of the flange attached to the tube machined at precisely 1.5 degrees off of vertical. I see a six bolt round flange of sufficient thickness so as to avoid any chance of failure at this joint. This might look a little like a fire hydrant but it would work. And all of this just to make a LBC go around a corner just a little faster. Oh my! Jack
