SCguy
My bleeding brakes question comes from my adding braided steel lines and a modified brake proportioning valve to my TR8. Unfortunately my new valve seems to weep brake fluid from the side closest to the fender. The new valve also seems responsible for adding a rust color to my fluid (This I noticed as I bleed my brakes). I was a bit suprised when I received the valve as is was no cleaner than my old valve and the valve's openings were not sealed off? Needless to say the valve will be going back to Ohio? Has anyone else had trouble with a modified valve? Is the valve really a huge improvement? I'm a liitle reluctant the replace the valve again as paint was damaged by the leaky valve /bcforum/images/%%GRAEMLIN_URL%%/pukeface.gif
