As mentioned earlier, I am restoring a MKIII BJ8, built in 1967th
Here is my real question.
I've just started the overhaul of the distributor. The installed distributor in my car is a 25D6 with the number 40920. After some research on the internet I found out that for my vehicle the type 25D6-40966 should be installed. The distributor installed in my car normally was used in vehicles earlier model years
After further research, I found that the characteristics of both distributer differ in some points. Thus, for example, the maximum Advance on my 40920 model is 15 degrees, in the later model 40966 is it 18 degrees.
Now, I wonder whether the differences in the Advance-curve a significant impact on the driving behavior, since both distributer models were incorporated into BJ7 or BJ8 cars with 3 liter engines.
Can I still use the distributer 40920, or should I replace it with the later model 40966, which would be associated with considerable costs.
