Mixture adjustment on Strombergs
Got_All_4
I have adjustable Strombergs on my TR250 and was planning to use my color tune to make some finer adjustments. I took a brief look through my manuals and did not see what direction to turn the adjuster to chance the mixture. So witch direction to lean it out?
TR3driver
Great Pumpkin - R.I.P
Clockwise = richer. You're turning a screw into a nut attached to the needle, so turning the screw "in" raises the needle for a richer mixture.
Don't forget, that screw is brass (hence relatively soft) and has a limited range. Don't force it. And if you back the screw out of the threads, most likely you'll have to remove the piston to push the needle carrier back in and engage the threads.
Got_All_4
Got_All_4
Thanks! I thought about taking the pistons out first then cleaning and testing the needle screw. Figure it would make things a little easier because the first time I tried it they were very stiff. I'm sure the rubber diaphragms can tear easily.
tdskip
If you have never rebuilt these carbs they are actually pretty easy to do, and it makes a big difference. If all she needs is some tweaking then no need to rebuild, but if you aren't sure how long it has been since it was last done I'd recommend you consider doing it. I just did mine and I found lots of issues and differences between the two carbs on the bits inside them...
poolboy
Randall warned you about the needle loosing contact with the adjusting screw threads. From fully Clockwise (rich) until fully Counterclockwise is a bit less than 3 turns. Call it 2 1/2 to be safe.
What I like to do is turn the screw fully CW, then CCW 1 1/2 as a starting point.
When I encounter diffficulty turning the screw, I take the air valve out, just to see the needles location and because it is safer and easier than trying to hold the adjuster when excessive torque is needed to turn the screw.
Sometimes it's the "star washer" that has gotten cockeyed thats creating the resistance.
tdskip
Between Randall and Poolboy you are <span style="text-decoration: underline">very</span> well supported here....
Keep us posted on how it goes!
Got_All_4
Got_All_4
Right = Richer
Left = Leaner
I like that! Reminds me of my boating classes. "Red Right Return". That's how my mind works. Now with age creeping up; how does that word association go?
Any way the carbs were rebuilt 9k ago. All 3 of them. Originally did an ear tune and checked the plugs. Now that I have the color tune it should be quite easy.
Just did the TR3 a few days ago and easy to dial in. Had to richen it up a bit twice after test driving. Spot on now. I'll be able to check mpg on the trip to TRF party almost 3 hours away. Looking forward to a good time. Taking both cars along with my son and daughter. This will be her first time to race. Look out Danica!
Got_All_4
Got_All_4
I'll do this monday. Worked around the clock since Fri night on both cars and still not done. 250 tume up turned out great!
Got_All_4
Got_All_4
TDSKIP asked to be updated. Well this worked out as well as the TR3. She runs the smoothest ever. I first balanced the carbs then bumped the idle to 1000 rmp. Then I checked # 2 cylinder. Could not get the color tune plug into #1 because the alternator is in the way. Doesn't matter as long as the carb you are adjusting is feeding that cylinder. It was very rich. Took a lot of turns to get it to indigo blue.
The middle carb was a little better but found out why the knurled top is on the guide. Holding it between your thumb and forfinger it keeps the piston from turning while adjusting the needle. I went as far as I could to lean it out. Could only get to blue with a yellow tick to the flame.
The rear carb was spot on and no adjustment there.
Re-balanced the carbs. It did change the balance and it runs very smooth. Even idles at 800 rpms with a mild street cam with 155:1 rockers.
Fresh plugs, good rebuilt carbs and a excellent tune job = smooooth running car! Can't wait to make the 3 hour tour to TRF.
J TR6 Stromberg Carb Mixture Adjustment Triumph 6
F TR2/3/3A Mixture Adjustment Su's Triumph 18
bugedd HS4 mixture adjustment help please Spridgets 13
BillyB62 TR2/3/3A SU H6 Mixture Adjustment Nut Triumph 16
memphis Fuel Mixture Adjustment Austin Healey 3
CraigLandrum Colortune vs Old School carb mixture adjustment Triumph 17
F Off Idle Mixture Adjustment with a Vacuum Gauge MG 0
H 62BT7 TriCarb Mixture Adjustment Austin Healey 14
V Where's mixture adjustment? Triumph 5
AngliaGT Mixture of Cars on My Drive Today Spotted 8
Michael Oritt Initial mixture setting for H6 carbs Austin Healey 3
steveg High altitude mixture observations Austin Healey 4
2billydavies TR2/3/3A Timing, fuel mixture, complete headache and total misunderstanding of it all Triumph 51
T Stuttering throttle response, mixture problem? Austin Healey 13
S Air/Fuel Mixture affect on Coolant Temperature? Spridgets 2
sundown TR6 1973 TR6 ZS carb mixture Triumph 2
D TR6 Carb Mixture Triumph 6
S Adjust mixture on a BT7 Austin Healey 9
M Carburetor tuning - setting mixture Triumph 6
P Mixture Control Triumph 4
M Warm days and air/fuel mixture Triumph 11
M Mixture control linkage Triumph 3
G Setting mixture on HS4 carbs MG 30
T Stromberg mixture how-to, once again. Triumph 38
drooartz Carb mixture question Spridgets 9
jvandyke mixture and exhaust note Spridgets 10
K TR2/3/3A TR3: carb adjust mixture ie. how many flats... Triumph 12
KVH Mixture and Exhaust Triumph 4
T new mixture attempt Triumph 21
E TR6 TR6 Cold Air Induction - Mixture Triumph 2
A TR4/4A TR4A mixture problem - need advice please Triumph 41
NutmegCT carb mixture H6 - exhaust Triumph 48
A Gas & Mixture Question Spridgets 19
S Zenith Stromberg Mixture Adjuster Restoration & Tools 13
E TR6 TR6 Fuel / Mixture ? Triumph 4
B Getting mixture right for emissions test Austin Healey 33
N engine falters when mixture screw tool is in place Triumph 5
S Anti Freeze mixture Austin Healey 3
A timing and mixture - do they relate Triumph 5
Simon TR4a Mixture theory. Racing 8
Slider748 TR6 How to adjust idle mixture on TR6 Triumph 10
G Mixture adjusting nut...which way? Austin Healey 18
Rick_Thompson TR2/3/3A Overheat issue, gauge adjustment Triumph 9
K TR2/3/3A Cylinder head removal and valve adjustment Triumph 2
K TR2/3/3A Gearbox clutch adjustment. Triumph 1
R Brake Adjustment Spridgets 2
R TR2/3/3A Clutch Petal Adjustment Triumph 2
charlie74 TR6 handbrake adjustment tool Restoration & Tools 0
R TR2/3/3A Rule 9 Valve Adjustment Triumph 8
F TR4/4A SU HS6 jet initial adjustment jet not flush with bridge Triumph 7
