homebeforedark
I disassembled a customer's BJ8 engine last night. The owner said that there was a problem with the crankshaft combined with low oil pressure so he parked it. That was about fifteen years ago. When I drained the oil and removed the filter , I found that there was no plate holding the filter against the housing so there might as well been no filter at all. The spring was there , though. The main bearings were severely scored and the rod bearings were only marginally better. This happened a few thousand miles after the engine got a turned crankshaft and a new rotor oil pump. It's a shame that after all that work a simple oversight led to another rebuild.
