Matthew E. Herd
Here's another doozy for you all. Lets see what we can figure out.
It would seem that the car has a dead miss in two cylinders ('76 Midget). It runs rough cold (who has a car that doesn't) but this prompted my mechanic (a touch obsessive) to start playing. Once again, we rechecked compression and found 225 in the rear three. However, when pulling plug wires, as expected, the engine RPM dropped significantly when wire 2 and 4 were removed. The unexpected part is that the engine RPM did not drop when plugs 1 and 3 were disconnected. The high tension wires for plugs 1 and 3 were switched (even though the order is 1-3-4-2 if i'm not mistaken and that's what was reflected by the distributor) and the car would no longer want to start. Under all circumstances, the spark arc'ed at least 1/2 inch from the distributor to ground. However, the lack of a wire on 3 did not seem to affect the engine as it was revved up to about 6000 RPM.
As an aside, I'm running dual 40mm Weber DCOM's.
Observations: 1 and 3 must contribute somehow if the car would not run at idle under these conditions (it would fire off, but not keep running without gas). I seem to have plenty of spark and the cylinders looked to be burning well, as when run for a bit, the plugs are golden brown. Compression is good in all cylinders tested (not 1). If the cylinders make compression and have spark, I suspect the following problems: out of phase sparking, or improper mixture. If the order is correct and the car runs, the sparking is most likely in phase. If the mixture is bad, the plug color would not be golden brown (incidently, when only run for short periods and started cold, the plugs are black. I suspect this to be a side effect of the fuel that is dumped in when the pedal is pumped a few times to start it.) Any experience with this problem?
