Well, you say it's running better and that is the good news.
I have a couple of suggestions for you that will be interesting little side projects.
First, either buy a new volt gauge or look for a nice used one on eBay.  Look for VDO if you can find it (not Smiths).  The VDO gauge will respond quickly to changes in voltage while the Smiths has VERY slow response.  Once that's wired in, glance at it periodically while you're driving... particularly when you notice the headlights dimming.  It might just be a minor fluctuation in the car's operating voltage that is the issue.  However, you'd really like to see the car's charging system operating at 1V to 1.5V over what the battery shows with the engine off.  You do not want to see alternator output higher than about 14.5V
The other project that may help with the headlights (possible... but harder on the wipers) will be to make and install a headlight relay panel.  There are kits out there for this but you can easily make your own using Bosch/ISO relays.  These relays are regularly available at auto parts stores and online from surplus companies like bgmicro.com.  The advantage of adding the relay panels is that the supply to the lamps is more direct through low resistance contacts.  Most people report consistently brighter headlights with relays installed.  The relays also take the load off your dash wiring and standard headlight switch.  This extends the life of those parts.
