My speedometer quit working a while back and I finally got time to jack her up to check the transmission end angle drive. After squeezing my fat body underneath with a light I noticed that there is NO angle drive there...the cable is screwed straight onto the tranny and makes a hard bend up toward the engine campartment. The speedometer had worked fine hooked up like this...although the cable does hang down pretty low I now so astutely notice.
I don't have time to mess with this now anyhow (due to the fact that there is also a HVAC system waiting in my garage and I need to move the B out when the HVAC guy is ready to tear out the old and put in the new) so I am wondering...
-Will I be able to just unscrew the cable, screw in the angle drive and attach the cable to the drive? Same thread?
-Is is safe to assume that I also need the angle drive on the speedometer end, since something broke...if it is there?
-What is the best way you all have found to R&R that angle drive?
-Do I really care how fast I am going? or do I need to know?
If anyone has any advice and insight, I would appreciate your thoughts on this.
Thanks,
Bruce
Thanks,
Bruce
