Yes, new points set at .015.Have you checked you point gap?
When my misfiring problem began several years ago, I tore the distributor down and cleaned and lubricated everything. It seemed in good condition considering it's the original distributor. At that time, I was convinced that the problem was in the distributor, so I found an advance curve for Lucas distributors and bought a set of springs to "calibrate" my distributor to match the original manufacturer's specs. I never got it perfect, but it wasn't bad. Eventually I replaced it with a Pertronix electronic distributor which was slightly better, but not the performance the engine should have. I retired, moved, and the car sat for a few years with me starting it once or twice a month. Now I have the original distributor back in the car and trying to debug the problem I've had for years.Have you ever looked at the centrifugal advance in the distributor? They are spring loaded lead weights with brass tubes in them sitting on a pin. Once the brass tube wears through the lead weights will disintegrate quickly. Mine were severely worn. This can cause timing to be erratic. It's fairly easy to check, just open the distributor and take the plate off.
Thanks for your help. I started at 15 flats and after warming used the "lift the piston" method which eventually took me to the 18 and 15 flat combination. That made me wonder if the needle was correct. When I tried to lean the carbs, I reached a point when the engine suddenly stopped firing and stalled. I was idling around 600 rpm. I like to idle at 450 when adjusting carbs, but the engine was rough when below 600.By the book you should start the jets at 12 flats and then you usually lean them down from there. That is often a couple of flats less.
Charley
Yes. I have two coils that I've been swapping. Both are fairly new. Resistance measurements are ok.new coil, right
Visually, all valves are opening and closing and appear to have full travel. Right now, the valves are set at .012 rather than .010 and .012. This was at the recommendation of someone in the forum. What symptoms would a flat lobe create? Will measuring valve travel with a drop dial indicator provide useful information?Maybe the cam has a flat lobe. Check and make sure the valve springs have full travel opening and closing. I pull the plugs and watch each one. Heck it would be good to check the tappet adjustment anyway.
steve
I checked for arching today and everything was ok.Thanks Steve, I have all new wires and was pretty careful to not have them cross or come close to ground, but it's a possibility. I'll run the check just in case.
I have the original 1/8 th inch steel pipe connected to the bottom of the front carb.Where is your vacuum advanced connected?
I have a new condenser and the float levels are good.Have you changed the condenser? and have you checked the float levels as they will directly influence the main jet adjustment.
Graham
The plugs are new and I haven't been able to run the engine enough to really get it hot (other than at idle) When I start it, I have to leave the choke on for about five minutes to keep it from stalling. After that, it runs ten minutes while I adjust carbs and timing. After cool down, the plugs have a light coating of black soot. I don't know if the black soot under those conditions tells me anything. I don't have another distributor to try. I ordered a new timing light so I can measure spark advance with changes in rpm to see if the distributor is advancing smoothly and matches original distributor advance curves. I can measure valve lift with a drop dial, but don't know how much lift I should be getting on a good cam. Do you have any information about valve lift with a stock cam?With a flat lobe the valve will not open not correctly or even at all. In this case the valve can be adjusted as normal because the valve will always be up and close. The problem happens because the spring does not compress and open the valve for fuel to get in.
When I have a problem like you have, I pull the plugs often and try to see something on the plugs that might be happening. Sometimes if the plugs are too clean there is no gas going to that plug or those cylinders. I had a clog in a float bowl chamber once that turned out to be a piece of the rubber seal had came lose worked its way into carb and blocked off fuel getting from the float bowl to the body of the carb. There is a 2 inch long by about 3/16 round hole in the base of the carb body that feeds fuel to the jet. When that plugged the spark plugs looked new because there was no fuel and the engine would idle, but not receive enough fuel to have any power.
Do you have a different distributor you can try.
steve
When I cleaned the carbs about six months ago, I ran wires down all the passageways to make sure they were clear. I think it's good, but you never know what can happen. I wonder if I can watch mist coming from the jets at idle with a borescope camera.The plugs are new and I haven't been able to run the engine enough to really get it hot (other than at idle) When I start it, I have to leave the choke on for about five minutes to keep it from stalling. After that, it runs ten minutes while I adjust carbs and timing. After cool down, the plugs have a light coating of black soot. I don't know if the black soot under those conditions tells me anything. I don't have another distributor to try. I ordered a new timing light so I can measure spark advance with changes in rpm to see if the distributor is advancing smoothly and matches original distributor advance curves. I can measure valve lift with a drop dial, but don't know how much lift I should be getting on a good cam. Do you have any information about valve lift with a stock cam?
They are now. About a month ago, I was convinced the carbs were running rich and it turned out to be one of the jets was sticking open in the choked position. That prompted me to tear down the carbs and replace jets, needles, and cork gaskets with neoprene o rings Moss sells. Since then the jets fully return.Is the choke/ the jets---- returning back to the base of the carb when the choke is pushed back in.
