Gblake2613
Of course when I got the frame back from blasting, the repair work that I had noted was all the more obvious. I don't have a TR4 shop manual to reference the frame dimensions; I only have the TR3 manuals.
Does any one have a link or a PDF of the TR4 frame dimensions from the manual?
Also, anybody have any luck straightening the front lower cross pin where the lower inside wishbones attach? I know that TR3 lower cross pins run parallel to the central axis of the frame, I assume they should on the TR4 as well. The drivers side pin is angled towards the center of the frame, or in, from front to rear by about 3/4". This might not be a problem, but I hate not to address it while I have the chance. Any advice on how to realign the pin?
In any case I will address the tab that has "pulled" away from the frame.
Thanks,
Greg
Thanks,
Greg
