Have a 1961 AH Sprite (Han6L/6608). I bought 4 Minilite repro's and have P175/70 R13's tires on the Minilites however the inside of the wheels (front only) are being cut into (by a millimeter or two) by the edge of the nut on the end of the shock absorber arm as the wheel is rotating. This is putting resistance of course on the wheel rotating freely while scraping the inside paint off the wheel. This only happens when the stearing is turned to the left or to the right. The same thing happened when I had the car jaked up and and noticed some inside wheel scraping as I rotated the wheel so I am not convinced the tires have anything to do with it (I assumed wrongly that the problem would correct itself when the car was lower back to ground).
I know the Minilite Repro has a good reputation and I am pretty sure it is not the wheel. Could the problem be the shock absorber? Anybody else had this experience? Puzzled... /ubbthreads/images/graemlins/pukeface.gif
